Old 11-17-2010, 12:52 PM
fire24resque's Avatar
fire24resque fire24resque is offline
Brake Question
Still having an issue with heavy dusting and excessive pad wear on the LF. New calipers both sides, new brake hoses both sides, flushed system, replaced master cylinder (unrelated but replaced). No codes, no pulling to either side.
The only thing I have yet to replace is the rotors - there seems to be a LITTLE visual runout but not enough to cause vibration or pulsation in the brake pedal...
Is it possible the rotor is responsible for this excessive pad wear and dusting? Warped/hard spots that are tearing the pad down? - I would think you'd notice a vibration or pulsation but I'm not.
2001 Silverado 4x4 - 4.8 V8 - Hankook Dynapro ATm RF10s, 265/75/16
K&N FIPK - Flowmaster 50 Series 3.5" Duals
4-Headlight Conversion Kit - Billet Grille
90 Watt Nova Strobe Pack
2.5% Limo Tint -
Check Out Pictures and More Here
http://www.cardomain.com/ride/2131569/1
Old 11-17-2010, 01:02 PM
Scrapper Scrapper is offline
AF Premium User
Re: Brake Question
are you sure the calipers are sliding back and forth? you may have to put some grease on where calipers side.
Old 11-17-2010, 03:14 PM
Re: Brake Question
They are brand new, fully greased and sliding.
2.5% Limo Tint -
Old 11-17-2010, 03:54 PM
inafogg inafogg is offline
Re: Brake Question
you dont mention replacing brake pads,did you replace with ''loaded'' calipers
dont think rotors would be the problem unless hot spots are in the rotor
but you say you dont see any
you can grease as mentioned where caliper meets spindle/knuckle
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-17-2010, 05:08 PM
j cAT j cAT is offline
Re: Brake Question
the hub bearing maybe worn. compare both sides for movement . should be none.
also remove the speed sensors, in the sensor hub hole take a sample of the bearing grease. if rusty/red in color the bearing is bad.
Old 11-17-2010, 06:19 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: Brake Question
Bad hub wont cause that much wear on the pads. What brand pads do you have?
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 11-17-2010, 06:53 PM
Re: Brake Question
with the pads replaced ,,,and the problem remains why do you think it is pad material ? these pads have been replaced ,,,,with the same resulting Left front dusting excessive only. a bad / worn bearing CAN cause this..all bearings do NOT fail exactly the same.........
If the rotor was distorted this would surely be felt in the steering wheel when braking.
swaping the rotors would be one last item to try... inspecting the front hubs at this time would be wise move !
Old 11-17-2010, 09:12 PM
Re: Brake Question
I had Napa Adaptive One pads on at first when the problem started. To prove it wasn't them I bought a cheap pair of $20 Autozone pads and threw them on, same results. The only thing left to replace is the actual rotor or go into the bearing. One question, as far as removing the wheel speed sensor to check the grease color, never did that before, what all is involved in getting that off/ to it, just remove rotor/bracket etc?
Thanks..
2.5% Limo Tint -
Old 11-17-2010, 09:20 PM
Re: Brake Question
jcat - 2001 Silverado 1500 4x4, are these hubs sealed or can you replace just the bearing?
2.5% Limo Tint -
Old 11-17-2010, 11:40 PM
kahjdh's Avatar
Re: Brake Question
No part of his post said pads were replaced even inafogg said that and if the bearing was bad enough to wear the pads that bad he would have noticed by now.
The calipers are sliding but are the pads?
Swap the pads side to side to rule them out.
Current Cars:
Past Cars:
Old 11-18-2010, 07:25 AM
Re: Brake Question
Pads are sliding just fine. I do notice a FEW symptoms of a bad wheel bearing here and there, very low speeds I sometimes hear a fine squeak (also think this may be a bad u-joint, have them to swap out one weekend) and also here and there a very fine click click click. Nothing beyond that - may be early signs but again is that enough to cause pad wear?
2.5% Limo Tint -
Old 11-18-2010, 06:12 PM
Re: Brake Question
the problem with these is the whole hub must be replaced..
I guess it would be possible to locate bearings and using a press replace just the bearing but no one does that ...
If the grease is not blue but rust colored its bad ...
removal of the speed sensor [need allen wrench] remove the stud then with light force rotate left/rt slowly and using penitrating oil pull sensor out...do not break ,,,it is cheapo plastic crap....
in the hole you will see the grease..My bearing failed by making a growling noise..brakes/or bearing being loose was not occuring ,,,,BUT the new bearing/hub assembly was much easier to rotate and the rotation feel was smooth..
replacing the hub is a pita...this was rusted into place very securely on my vehicle...lots of penitrating oil and careful hammering force the hub off...with the surface cleaned and lubed with anti sieze the new hub fit in with not much force..
I got my hub at 1A AUTO comes with a one year warrantee and was about 70.oo..........also comes with new sensor..
so far it is working great...
when you remove the rotors swap them lft/rt check all this out....then if you still have the lft side still wearing more this will most likely be this worn bearing with too much end play...movement ..
wire brush the rotor/hub surfaces thoughly on the mating surfaces ,,,,,,when installing the rotors...
when I checked my noisey bearing just for the hell of it I pumped grease into the sensor hole,,,lots of grease...ran vehicle for about one month just to see what would happen...had new hub ready to install,,,,,,,,made less growling noises....do not get worse...
Old 11-18-2010, 06:58 PM
Re: Brake Question
I have a BAD feeling you are right with it being seized on, when I replaced my rotors at 70k the bracket bolts were FROZEN and I had to grind them off, I'm at 130k now I can only imagine how these will be. First check is going to be pulling the speed sensor and checking grease. I jacked the front today and had NO play in the wheel, holding at 6 and 12 and rocking it, it was solid. I have no groaning, whirling, grinding, just an occasional squeal at low speeds (again think it may be ujoint OR the rubber boot at the CV as it touches itself makes a rubber squeak). I'm so afraid of yanking the speed sensor out and breaking it off, if/once I get it out, how do you put it back in, just push it in?
I am actually ready for new rotors but I don't want to put new ones on until I rule everything else out and chance ruining them - like I said before I have cheap ass Duralast pads on there from Autozone just as a test so they will be replaced also with the new rotors. I will try the swap and see what happens, I really hope it's the rotor. Thanks for your input, just wondering how to put the speed sensor back in if you can let me know, thanks.
2.5% Limo Tint -
Old 11-18-2010, 07:38 PM
Re: Brake Question
that squeal is most likely the pads constantly rubbing, when hot make these sounds..
if you use the penitrating oil [NOT WD-40] AND BE CAREFUL AND EASY ON IT ,,,it will come out...putting it back it will slide in ...then screw the allen stud down to lock in place.
wash down the area first / use a small wire brush,,,then apply the pentitrating oils...
Old 11-19-2010, 07:23 AM
Re: Brake Question
One more question - I had the wheel speed sensors replaced under that recall a few years ago. When I first started having this issue I checked for ABS codes (never once had a light come on) and there was some old ones store in there regarding the wheel speed sensors malfunctioning. From what I was told those codes don't stay forever, they clear after so many key revolutions, so it tells me they were somewhat recent. Again, no light ever came on. Do you think a wheel speed sensor error could cause anything like this??
2.5% Limo Tint -
Another 2004 Alero hub assembly and front brake question. Seattle Al Alero 3 02-20-2009 07:38 AM
Brakes questions... AlwaysMovin '88 - '91 Civic | CRX | Wagon | Shuttlee 2 05-10-2003 03:58 AM
Now I have a brake question?? Killa_CRX '88 - '91 Civic | CRX | Wagon | Shuttlee 3 11-07-2002 03:15 PM
Brake question Fliquer 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 0 09-30-2002 05:59 PM
brake question SublimeLAD '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 5 03-31-2002 04:00 PM
