Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 11-16-2010, 11:33 PM   #1
erope123
1997 3.1L a/c by-pass pulley?
My a/c unit has not worked for several years (blows hot air). I want to remove the a/c compressor and replace it with a bypass pulley. Is this a pretty straight forward repair? Anything special I need to know?
After starting my car this am and letting it warm up for about 5 minutes, I went outside and it was making a 'bell/ringing/chinging' like sound and found the noise was coming from the a/c compressor. I put a little oil between the pulley and the clutch and the noise stopped. MUST drive north in 2 days, so going to attempt the fix myself in 12 hours.
erope123 is offline   Reply With Quote
Old 11-18-2010, 08:26 AM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: 1997 3.1L a/c by-pass pulley?
Nothing special. You'll pretty much ruin your A/C for life once you open it up and leave it exposed to the elements. If that's not a problem, go for it. If you have any hopes for ever getting it fixed, I'd do something different.
Maybe a junkyard compressor and some new o-rings?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 11-22-2010, 12:25 PM   #3
kevinb70
Send a message via AIM to kevinb70 Send a message via Yahoo to kevinb70
agree with leaving it alone. You just have a clutch plate misaligned a bit causing the ringing.
1999 Dodge Ram 1500 2WD 5.2L NV3500
1998 Chevy Lumina 3.1L (2010 DIY intake/head job, 2011 DIY A/C replaced, ran like a top til I sold it in 2014)
1999 GMC Sierra 4.3L
2014 Toyota Prius Four
kevinb70 is offline   Reply With Quote
1997, 3.1l Lumina - ignition mystery? Artem F Lumina 14 10-05-2010 08:19 PM
95 3.1 Air Conditioning nato38 Grand AM 4 06-30-2010 08:23 AM
Cooling fan problem on 91' 3.1l Need some help marklar34 Lumina 5 04-16-2009 09:50 PM
90 Lumina Euor 3.1L Passing Gear Problems townsend11234 Lumina 3 11-29-2006 11:47 AM
1997 3.1l LyndsiK Grand AM 1 11-30-2005 04:45 PM
