Old 11-16-2010, 02:06 PM
betuaintgotthis betuaintgotthis is offline
Unhappy HELP Green marking on master cylinder
Hi all just wondering if anybody could help me out.
I have a brake assessment tomorrow and have to answer a question and am clueless on the answer.
heres the question
What type of brake fluid is used on a vehicle with green colour coding on the master cylinder reservoir
Just spent an hour on google with no luck.
Would be massively appreciated if somebody could help out.
Old 11-16-2010, 04:03 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: HELP Green marking on master cylinder
heres the question
What vehicle are we talking about?
Check the owners manual to determine what type of brake fluid to use(IE: Dot 3, Dot 4).
The green marking is probably meant to help you locate the master cylinder not to specify what type of fluid to use. Just like the oil dipsticks are usually yellow.
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 11-16-2010, 04:12 PM
This is refering to in general the answer is either
Synthetic
Vegtable
Mineral
Non-mineral
Im thinking mineral but can not find anything to back that up
Old 11-16-2010, 11:03 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
That's probably correct. According to this article on page 3 (found through Google), "Note that a third category of brake fluids exists – mineral fluids. These are used in some Citroens, Rolls Royces, Audis and Jaguars. These systems use pressurised oils in systems that have no SBR compounds. These fluids are coloured green."
-Rod
Old 11-17-2010, 02:43 PM
Well I took the test and passed (phew) but was aloud to get 4 questions wrong. Unfortunately I dont get told which ones I did get wrong/right.
Still thinking that mineral sounds right but dont recall seeing any green markings on the citroens LHM tanks.
Just wondering though if anybody has seen a green brake fluid resivoir cap. Maybe that means the same thing. Im curious now even though the test has been done.
Help! ABS light and master cylinder problem Help! ryanisfast Prelude 6 08-10-2005 05:06 AM
Need Help with '84 master cylinder TonyMadrid Corvette 0 08-14-2004 08:56 PM
help fast!! 91 master cylinder momof2 Grand Prix 3 08-11-2004 11:41 AM
Help!! No Breaks, Master Cylinder help Hondabots '88 - '91 Civic | CRX | Wagon | Shuttlee 2 05-04-2003 12:28 PM
