Old 11-16-2010, 07:02 AM
rdruschel66 rdruschel66 is offline
99 grand am overheating v6 3.4L
1999 Pontiac Grand Am SE
V6 3.4 L
170000 miles
Original problem, car overheated and service soon light.
Service engine soon light directed me to misfire cylinder 1, replaced spark plug and corrected service engine soon light.
Now the overheating issue, replaced thermostat, no heat, and car overheats.
Flushed heater core both directions with garden. No heat until thermostat opens. Initial start car overheats and thermostat does not open. After warming car up and shuting off the thermostat finally opens. Its acts like once the thermostat opens it is fine but the first startup the car overheats.
Bleed cooling system Did get some air out. .Blew air thru bypass line and another line back to coolant reservoir to check for blockages, no blockage found.
Last night once thermostat open went on 20mile drive car acted fine thermostat seem to open when it should car did not over heat. The only thing I notice the vents would blow hot air and then cycle to cold and then back to hot.
Sat car for about .5hour topped off coolant fluid and initial start it overheated, thermostat did not open.
How does this bypass from top of water pump play in all of this?
Does this sound like an air lock?
Should I flush radiator?
Should I drill holes in thermostat?
Thanks for any help in advance.
Old 11-16-2010, 04:31 PM
thephantom1492 thephantom1492 is offline
Re: 99 grand am overheating v6 3.4L
I'm worried that you have a faulty water pump.
I would advice against the hole drilling.
Also check to be sure that you don't have bubbles. If your engine overheated it could have cracked a gasket.
The hot/cold is usually blockage, air trap or faulty water pump.
Old 11-24-2010, 05:20 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Sounds like air trapped in the cooling system. Most likely trapped in the heater core loop.
Though this might not explain why it overheated originally.
Was it low on coolant, or was the thermostat the cause..?
You could check your water pump. Easy to remove and a fairly cheap part.
1999 Grand Am SS 3.4 OHV
1995 Pontiac Grand Prix, 3.4L, DOHC question? female in need of help! Beck18 Grand Prix 1 07-31-2006 06:04 AM
1992 Grand Prix 3.4L V6 DOHC high engine idle at cold start melissa_sj Grand Prix 0 01-20-2006 06:23 PM
sunfire vs grand am 3.4L v6 sirsmiley Car Buying Q&A 5 03-16-2005 04:13 PM
1994 Grand Prix 3.4L Idling Problem corvettecat Grand Prix 2 02-23-2005 11:05 PM
need a transaxle off a 95' GT Grand PRix 3.4L crazydriver7686 Grand Prix 0 05-03-2004 01:38 PM
