Old 11-15-2010, 07:16 PM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
U joint
(specs in sig)cant figure out which u joint i need!
I need to replace the u joint on the front shaft near the t-case
autozone lists 3 different ones for front shaft, i have no idea which to get. It doesnt seem the bore in the yoke is deep enough for those snap rings to go in there to hold in, the existing joints stick all the way out to flush
1-0445DL this is the one i bought it has 2 sets of the rings
0153DL this one has all 4 snap style rings
If you have some insight, let me know!
5374DL this one seems to look the same as first one
im guessing i need to just use the one with the inner clips for the yoke, and the other part of cross gets bolted on with clamps, but im confused....lol
1991 Jeep Wrangler 4.0 (3rd child or 2nd wife)
1999 Chevy Suburban 1500 5.7
2005 Toyota Rav4
1994 S-10 Blazer 4.3L "W" "Dead and gone"
Old 11-15-2010, 07:36 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
Re: U joint
Your existing U-Joints are probably held in place with molten Plastic that was injected into a tiny hole in the yoke and then cooled. I doubt that there are grooves inside the holes of the yoke that the spring clips will fit into, If memory serves, when I did mine, the C-shaped clips were installed on the inside of the yoke, in the grooves of the cap, and if there is a U-Bolt to hold two of the four caps, then you would obviously only need 2 clips. Have you ever replaced this type of U-joint before?
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr.
Old 11-15-2010, 08:09 PM
Goober
Re: U joint
Its been awhile, I have done the melting out before an another truck.
this one doesnt seem to have the weep holes on the yoke though. Im taking it (shaft) to the shop at work tommorow to try and press it out, just trying to decide which one to buy, i currently have the top one listed, which i think will work but not sure
2005 Toyota Rav4
Old 11-15-2010, 08:27 PM
Big Tall Dumb Ass
Re: U joint
If you have U-Bolts on this specific yoke, I think you're right with picture number 1. Besides, #1 looks a little beefier in the middle section. I'd also have a plumber's torch handy to heat up the yoke.
Old 11-16-2010, 06:39 PM
Goober
Re: U joint
There was no nylon or heating needed, i just used the 2 sockets and a vice method and it popped right out.
That is, after i realized there were clips on the old one that were rusted over and i didnt see right away....
If nothing else maybe this will help someone else searching for it, i used the top picture shown for the 94
2005 Toyota Rav4
Old 11-16-2010, 06:42 PM
Big Tall Dumb Ass
Re: U joint
Good Job, Glad to know you got it done.
I've seen the rusted over clips before too. Makes ya feel kinda loopy when ya figure it out.
ball joint? tie rod? HELP! cjedstrom Cougar 2 11-26-2009 05:53 PM
CV Joint/Ball Joint (?) 1996 Cavalier CrudesPeyote Cavalier Problem Diagnosis 3 05-30-2008 02:59 PM
How to replace ball joints/axle u-joints dave92cherokee FYI - How to... 1 10-02-2007 08:28 AM
Bad CV joint or Ball Joints or none...2000 Jetta GLS emoskater84 '97 - '03 5 05-01-2007 02:54 PM
tahoe cv joint and front drive shaft U-joint repair? mhamilton410 C/K 1 07-20-2004 11:45 AM
