Old 11-15-2010, 04:12 PM
motorhead92 motorhead92 is offline
Help!!!
Ok so i spun a rod bearing in my d16a6 so im swapping it with a d16a1 are all the mounts and plugs the same and how much more hp will i get ?
Old 11-15-2010, 11:56 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: Help!!!
The D16A1 won't fit in there very easily - it's actually a different series motor. The motor mounts are way different. You'd be better off fixing the A6 or finding another block than trying to fabricate new mounts and stuff for the A1.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 11-16-2010, 07:04 PM
Re: Help!!!
But its possible? and does the a1 have more hp than the a6? And what will i all need?
Old 11-16-2010, 10:06 PM
4G4D Store's Avatar
Re: Help!!!
I don't know of anybody that has actually done this. You'll gain like 4hp and 1 less torque for all the work you'll put in to it, it's not worth it. I've heard of people trying, but gave up because of the amount of fabrication required. You'd do way better dropping a z6 or a zc or another a6. The ZC is over 130hp - which would gain you about 20hp, the z6 is 125hp which is a 15hp gain - way more than the A1 and they are drop in and plug in practically - no fabrication.
Old 11-17-2010, 10:31 AM
Re: Help!!!
So whats the best engine to drop in it without having to mess with the mounts and plugs and that will give me the most hp with dual cams?
Old 11-17-2010, 12:02 PM
Re: Help!!!
And how do i tell if a engine is a zc or not?
Old 11-17-2010, 08:46 PM
Re: Help!!!
Will a crankshaft from a d16a1 fit in a d16a6?
Old 11-18-2010, 09:10 AM
4G4D Store's Avatar
Re: Help!!!
The ZC is the only drop in motor that will drop in without any modification. "ZC" is the actual engine code - you usually have to import them or find somebody that has one - I don't think that they were ever released in any US cars.
Old 11-18-2010, 09:23 AM
4G4D Store's Avatar
Re: Help!!!
The crankshafts are different I believe as well. The second best motor to drop in is the D16z6, but it will require a little rewiring. The ZC isn't as easy to work on because it's kinda the ugly headed step child of the d series motors. The z6 is going to have more support for aftermarket and upgradable parts.
Old 11-18-2010, 08:16 PM
Re: Help!!!
Can i put a twin cam from a d16a1 on a d16z6?
Old 11-18-2010, 09:00 PM
4G4D Store's Avatar
Re: Help!!!
Nope, the head bolt patterns are different. Even the ZC head won't bolt to a single cam block.
Old 11-19-2010, 08:30 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Help!!!
Dont get in the mindset that SOHC isn't worth anything, they can put out some power.
The A1 is out of the old integras, its a common swap with the 1g Crx because its one of the only engines that will drop right in those chassis.
Z6 is possible to drop in without rewiring, just use your current distributor and ECU. It performs better if you convert to OBD1 and use its distributor and ECU, but its not necessary.
As he mentioned, the z6 will have more support than the ZC. If you were wanting to build an all-motor engine, the pistons out of the A1 are actually perfect for the z6, will bump the compression up to 11:1-12:1 depending on a couple variables. Z6 is also a good turbo engine, I hear Vitara(i believe) pistons are great for turbo setups, will lower the compression from stock to allow more boost.
Niether engine, z6 or zc, will require different mounts, wiring is just variable. I would suggest switching to OBD1 at some point, if your going to build its almost necessary so you can tune it.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 11-23-2010, 04:26 PM
Re: Help!!!
So i swapped my d16a6 with a z6 and i sit in my car to smoke before we tried starting it and i turned the key to on and the check engine light flickers and ticks or buzzes and there is this wire in the engine that looks like it would go in the battery but cant find where it goes maybe the problem idk.....
Old 11-23-2010, 05:01 PM
Tony's Avatar
TLD Member #1
Re: Help!!!
Not enough info man. There are a lot of wires under the hood. I don't know what all you swapped over, I don't know how I should tell you to check the Check Engine light, etc.,
Tony
Old 11-24-2010, 04:17 PM
Re: Help!!!
ok so i swapped my a6 with a z6 but used the a6 head (non-vtec) and stuck with the same ecu from the a6 when i started it today it runs but idle at a little over 2000rpms then after 30 secs or so i jus rev all the way up do i need the ecu from the z6 and if so will it plug right in to my a6 wireing dont have a lot of money so im trying to fix this problem cheaply jus so i can get it out of the garage and does the head from the a6 make a different in it running like shit let me know thanks.....
