Old 05-22-2003, 03:00 AM
carmenCRX carmenCRX is offline
Balljoints Question
Does anyone know if a car's wheels will actually fall off if the balljoints are totally worn and don't get replaced? Mine are worn and I was told that the wheels can just fall off if I don't fix them!!!!! Ever since then I'm kind of afraid to drive, and I'm really poor so I'll have to save $$$ to fix, although they can't be toooooo expensive to fix.
Thanks
Old 05-22-2003, 03:13 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Iv seen some pretty wrecked ball joints in my time, but I have never heard of one comeing apart due to wear.
However I guess that if let to get to worn its possible it could over heat, sieze and break, which would be catastrpohic if you were traveling at any speed.
You should get it replaced simply to save excess wear to your tyres.
Old 05-22-2003, 03:16 AM
OK...Thanks. Do they wear on the tires a LOT ???
Old 05-22-2003, 03:21 AM
Moppie's Avatar
Master Connector
Well it means the wheel is able to move around with the lose joint, its its worn enough then the alignment goes out, which increases tyre wear.
The cost of a new ball joint, and the 20mins it will take to fit it will easily pay off in savings to tyre wear and stress on the rest of the suspension.
Old 05-22-2003, 03:37 AM
Do you know if this situation could cause problems with my tires aside from wear? They are only 40,000 km's old, the tread is still "like new" but, recently I have just noticed something that looks like a manufacturers defect --- or something like that. The tread is good but it looks like there's little "dents" or small pieces missing or .... like scratches almost, hard to describe... not all over the tires, but there are a lot. Anywayz, thanks for your help, I will for sure get new balljoints soon....
Old 05-22-2003, 04:49 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
sounds like your tire is chunking, where small bits are broken off due to bad suspension setups.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-04-2003, 04:51 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
yes you should change the ball joints, becasue although the tire wont fall off, on two seperate occasions i have broken balljoints, one resulting in a wreck. one time the balljoint shaft snapped, and the control arm came off the knuckle, and the other time the threaded end of the shaft broke right where the cotter pin goes in at, which resulted in the castle nut coming off and then the balljoint coming out.
i do drive my car like a lunatic though.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-06-2003, 07:31 PM
I used to drive like a lunatic... I won't till I get new joints.... though.
I wouldn't be surprised about my tires... whoever had my car before me lowered it and who knows what's going on with the suspension, I know they aren't chopped springs, they were actually proper new lowering springs, but I don't know the condition of my shocks, etc. Damn I wish I had more $$$
Thanks for your input guys!
About the chunking tires... how does that actually happen to them???
Thanks...
Old 06-06-2003, 08:00 PM
EF You's Avatar
EF Life Giver
chunkin happens cause of a bad alignment. camber wears the edges, and toe can cause chunking.
Old 05-07-2004, 03:58 AM
Smoakie976's Avatar
Smoakie976 Smoakie976 is offline
Re: Balljoints Question
I cannot get the castle nut back on the ball joint......why? what is the problem?
1998 honda civic ex
b16a2
AEM intake
HKS HiPower Exhaust
Skunk2 front camber kit
2000 Si rear bumper
99 Si wheels
pioneer p9000 head unit
jl audio w6 12" sub
Rockford Fosgate 250x2 amp
976 Crew
Old 05-07-2004, 07:15 AM
EF You's Avatar
EF Life Giver
the threads are probably damaged. sounds like you are gonna need a new balljoint. DO NOT ATTEMPT TO RETHREAD
Old 05-09-2004, 11:34 AM
Smoakie976's Avatar
Yeah I kind of figured that and already planned on it...so that is what I am going to do! thanks man!
1998 honda civic ex
b16a2
AEM intake
HKS HiPower Exhaust
2000 Si rear bumper
99 Si wheels
jl audio w6 12" sub
976 Crew
Old 05-10-2004, 12:16 PM
Tranzlogic Tranzlogic is offline
Send a message via AIM to Tranzlogic
new ball joints are a must in that case ! you dont need to go dealer tho, carquest,napa,autozone will be fine..there all made the same and the dealer will be a furtune ine comparison
