Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 11-14-2010, 09:22 PM
zmame zmame is offline
01 Impala 3.4L Idle issues
Hello i'm the lucky owner of a 2001 Impala 3.4L
I'm having issues with idle some days its fine others it revs a little high (it will cruise at 40mph w/o gas pressure) Some days it screams. some days its normal.
Here is what i done
I unplugged IAC when car was running normal and it will run normal all day long with it unplugged. If I plug it in and drive for a while it acts up. So I replaced IAC and cleaned IAC ports with q-tips and TB cleaner. It no longer screams like it use to some mornings. But still have issue with it driving the idle will creep up to where i have to ride the break in town.
Now here is what i noticed as soon as i unplug TP sensor it stops high idling.
Do you think this could be a faulty TP or is there somthing els that controls the idle
Old 11-15-2010, 07:49 AM
maxwedge maxwedge is offline
A990 racer
Re: 01 Impala 3.4L Idle issues
A bad tps can cause this but without a proper scan it would be guess work.
Old 11-15-2010, 11:28 AM
jdl jdl is offline
Any applicable codes? You may need to take the throttle-body off and clean it, all passages. The pcm uses the map sensor to determine if tps signal is in range.
Old 11-15-2010, 11:35 AM
No there is no codes being thrown. Unfortunatly I do not have a scanner to read tps only hand held code grabber. I bought a TP sensor it was cheap enough I'll try that if it dosen't work then I will take your advice and remove and clean TB.
Thanks a mill for both your guys help
Old 11-15-2010, 11:39 AM
jdl jdl is offline
You could use a digital multimeter on the tps signal wire, key on, move throttle up and down, see if voltage signal moves up and down smoothly?
96 Cutlass Supreme 3.4L DOHC Idling high and not shifting properly 96cutlass3.4 Cutlass Series 8 06-18-2010 04:46 PM
1996 Monte Carlo Z34/ Cutlass Supreme 3.4L Idle Learn Procedure 96cutlass3.4 Monte Carlo 0 06-17-2010 10:43 PM
01 Impala 3.4L Cooling and Trans. issues..Need Help! samuelcb409 Impala | Impala SS 1 08-10-2009 03:51 AM
3.4L 1996 Cutlass Supreme Help please!!! Zca62783 Cutlass Series 0 02-14-2009 03:27 PM
2002 Impala 3.4L Marsal420 Impala | Impala SS 0 03-04-2006 06:39 PM
