Old 11-14-2010, 02:33 PM
freds blue ford freds blue ford is offline
95 for w-star engine surging
My 95 ford w-star Lx 3.8L enging surges from 600rpm to 900rpm but only when the vehicle is stoped in gear, i.e at a stop light.
Any ideas out there??
Thanks
Old 11-14-2010, 03:20 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Re: 95 for w-star engine surging
Hello and welcome to the forum!
Try taking a look at the IAC valve; I'm not sure about the 95 model but it should be located at the throttle body it has a 2 pin connector running to it. It may be dirty or full of carbon and the PCM cannot properly adjust it causing the RPM's surging. If that doesn't helps try cleaning the MAF sensor with MAF cleaner.
Best regards,
Oscar.
1995 Lincoln Town Car 4.6 Signature
1997 Pontiac Grand Prix GT 3.8
2000 Ford Windstar SE 3.8
Old 11-14-2010, 04:13 PM
Thank you very much, i will post my results.
I took out the IAC it looked to be in very good condition, no corrosion at all.
I haven't got to anything else because i am so busy working.
I will try all of the other helpfull tips this weekend, ''i hope''
thank you .
ps it does serge at any teperature, but only when it is in gear and stoped, or trying to stop/park
Old 11-16-2010, 09:05 AM
mark_gober mark_gober is offline
Surging could indicate a vacuum leak. A big culprit on these vans is a vacuum leak on the hard plastic tube that resides on the back of the motor on the passenger side. (on mine it's red).
Correct me if I'm wrong, but I believe faulty IAC's usually manifest themselves only when the engine is cold. I had one and thats what mine did. It idles like crap until it warmed up. After that, I never had the problem again. It acts like a choke.
Mark
Old 11-17-2010, 08:52 PM
wiswind wiswind is offline
The IAC can act up at any temperature.
The IAC is more like a mini-accellerator, it opens a path for air to bypass the throttle plate in the throttle body.
The intent is to have the computer (PCM) control the airflow (idle) when your foot is off the accellerator.
The IAC has a small motor inside that drives a "screw" that opens and closes a valve.
It could stick only when cold, all the time, or who knows when.
The FIRST step is to try to clean it, using something like the spray version of SeaFoam or even WD-40......which will leave some lubricant on the threads of that screw so that it moves more easily.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 11-18-2010, 08:48 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
If it was a problem with IAC, it will show different symptoms. It's not the IAC.
It's either a problem with vacuum leak or maybe the MAF sensor is dirty. Or the O2 sensors. That's the most probable culprits in descending order.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 11-19-2010, 05:45 AM
kafkacell kafkacell is offline
Fooling around
Do you have CEL on? (check engine on).
Hyundai Elantra 2001 GLS
YOU ONLY
NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND
SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
1993 JGCL Engine Surges, Check engine light Jeep93GCL Grand Cherokee | Grand Cherokee SRT8 5 06-04-2005 10:38 PM
Engine Surge to go with check engine light SootheMyPain Passat 2 05-06-2004 01:41 PM
