Old 11-14-2010, 07:22 AM
Scottm69s Scottm69s is offline
95 Blazer Won't Start
Hello, I have a 1995 Blazer. The other day I was working on my trolling boat motor and wanted to plug it into a battery to test. I started up my Blazer and brought it inside my garage. I shut it off and hooked up the motor. Tested the motor and other worked. I jumped into my Blazer to start it up and it just made one click and nothing. I tried jump starting it and could not get anything to happen. For the past few months the Volts have been moving on the gauge from the middle down to the red at times. Could I just have a bad alternator????
Old 11-14-2010, 08:56 AM
jdl jdl is offline
Re: 95 Blazer Won't Start
With everything turned off, what is the voltage reading across the battery posts? Use digital multimeter. The generic spec for a full charge is 12.6 volts. If the battery is down, take it off and get it charged. With engine running, take second reading across battery posts. The second reading should be higher than the first if the charging system is working.
Old 11-14-2010, 12:17 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
How long or how much did you run the trolling motor or leave key on or listen to raido?
Just a short test should not kill battery.
Have you checked the batery terminals for clean and tight.
AS said check battery voltage at battery.
If not 13.4-13.6 volts charge or replace battery.
Then check alternator out put.
Post back how it goes.
MT
2000 Chevy Blazer won't start after replacing blazer AustinJ! Blazer 5 02-27-2005 10:14 AM
96 blazer won't start. problem started during freezing weather. LukeBickers Blazer 3 12-31-2004 03:33 PM
96 blazer won't start . . . sometimes a&k Blazer 2 11-16-2003 07:45 PM
1994 Blazer Won't Start Will-01 Blazer 6 09-09-2003 11:22 AM
Blazer won't start when hot timh059 Blazer 3 06-08-2003 08:41 PM
