Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 11-13-2010, 07:11 PM
Kscha41 Kscha41 is offline
89 Cutlass Supreme stalling
Hi I'm new to the board. I hope you guys can help me out. I'm trying to help out a friend get her car running again. Here's the problem. I guess the car is stalling out a lot especially when it warms up. She says it starts right up again after it stalls. It also will not go over 2000 rpm. She says it doesn't stall at 2000 rpm but it acts like it is being governed. We have replaced the IAC and the throttle position sensor and that didn't help. The car has the 2.8 ltr motor in it. Thanks so much in advanced.
Old 11-14-2010, 08:41 AM
maxwedge maxwedge is offline
A990 racer
Re: 89 Cutlass Supreme stalling
Welcome to AF. First you need to scan for codes, then test the fuel pressure when it dies out.
Old 11-14-2010, 08:48 AM
Thanks for you response. How do I scan for codes. I know autozone won't scan anything older than a 96 or 95. As for the fuel pressure, what am I looking for when it dies.
Old 11-14-2010, 09:26 AM
elca69 elca69 is offline
I've had trouble with ignition module and coil packs acting that way on a 3.1 engine...Good Luck
Old 11-14-2010, 02:06 PM
Well I rented a fuel pressure tester today. I hooked it up to the car. Once I hooked it up I turned the ignition on but didn't start it. It first went to 40 psi then went down to 36 psi. Once I started it up it went to 44 psi and it ran like crap. It wouldn't rev up. It would just die. Then after starting it up a couple of times it went to 37 psi and ran great. It would rev and run. It would even run great when warm. But once the psi went up to 44 psi even when warm it would chug and die. So now I am thinking it may be the fuel pressure regulator.
Old 11-14-2010, 02:21 PM
inafogg inafogg is offline
did you check pressure with engine running with the fpr vacuum unpluged??
is the vacuum line wet with gas??
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-14-2010, 02:48 PM
No I didn't. Where is the regulator at on this car? What would happen with the regulator vacuum line unplugged?
Old 11-14-2010, 06:49 PM
A990 racer
A no vac situation to the press reg would cause high fuel pressure, it is part of the fuel rail.
Old 11-14-2010, 07:06 PM
Hmm so maybe the vac line is broken or loose. I will have to check before putting a new one on.
Old 11-14-2010, 07:35 PM
Well doing some more searching online, its looks like the reg is between the two rails, dead center of the engine. It also looks like you have to take off the intake manifold to get to. Does anyone know if this is true?
Old 11-15-2010, 07:55 AM
A990 racer
Upper intake must come off.
93 Cutlass Supreme SL Stalling eyeintheskyfthp Cutlass Series 5 08-12-2010 01:49 PM
Cutlass Supreme - which power steering fluid serge_saati Cutlass Series 1 12-07-2009 07:15 AM
1992 oldsmobile cutlass supreme stalling LenInEdmonton Cutlass Series 8 07-28-2006 09:57 AM
91 cutlass supreme stalling problems nolimitsoldier Cutlass Series 2 01-08-2005 11:32 AM
1996 Cutlass Supreme Stalls shleprock Cutlass Series 1 01-23-2004 01:35 PM
