Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 11-13-2010, 04:00 PM
eric1h eric1h is offline
Headers project has begun!
About 4-5 hours under my belt and the first side is fabbed up... Came out nice... But the hard side is left to do!
Ill post pics shortly
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 11-13-2010, 07:37 PM
NZGTRA17 NZGTRA17 is offline
Re: Headers project has begun!
Eric, what diameter and length primaries are you using? Are you staying dual system or converting to single system?
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 11-13-2010, 08:22 PM
Kel.
1-3/4" primaries
i tried to get each one @ 31" but they range @ 28"-31"
Still has to be a LOT better than what I have now!
A few pics...
Old 11-13-2010, 09:51 PM
1-3/4" primaries
A few pics...
Lookin good Eric. You will have fun getting to some of those welds.........!!
I have started to think less now about equal length and more about equal flow. I.e if you have a pipe that has tighter turns in it that will slow down the gas flow, then it is OK for that pipe to be a bit shorter as the gas flow time will be same as a slightly longer but straighter pipe. Equal length does not = tuned length.
I may be making up another set of primaries at some stage for the 369 as I will be stretching my current set a little far and sacrificing some hp as I will most likely be running a long duration solid roller cam. My primaries are 36" so great for building torque in a 5.0 or 347 engine (pipes ran 335 and 390rwhp on these engines with torque approx the same numbers).
A run on the dyno will tell and if we dont hit the power numbers that we are expecting I will offer the current headers up for sale. Anyone with a 5.0 or 347 powered car interested?
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 11-13-2010, 10:16 PM
Thanks kel, they should do the trick I hope, we'll see
As for the welds. I plan to take each tube off(just tacked to the flange stubs, weld each tube seperatley and then reaassemble.. Should make for a much easier time!
Kel.
Old 11-14-2010, 04:43 PM
PanozDuke PanozDuke is offline
Kel,
If you are interested in selling your original 8 into 1 headers, I'm very interested. [email protected]
Mike
Old 11-14-2010, 04:50 PM
Originally Posted by PanozDuke View Post
Kel,
Mike
What, no comments about my headers? Sheeesh! Lol
Old 11-14-2010, 04:51 PM
Kel,
Mike
Hi Mike, I wont be back in NZ working on the car again until late Jan 11. I have to get the 369 together aand then on the dyno to determine if the current headers will suit the bigger and angrier engine. If shorter primaries are required to extract the best from the 369 I would rather sell the original set rather than "hack them up" to suit the new engine. The headers have been thermal coated so if I do any cutting and welding this coating will be destroyed and it is $400 to recoat them.
I will keep you posted on progress Mike and whether the headers will be up for sale. Thanks for the interest.
Kel.
Kel M
Panoz GTRA #17
New Zealand
Old 11-14-2010, 10:02 PM
Paul Buxe's Avatar
Paul Buxe Paul Buxe is offline
Eric
Headers are looking good. I feel your pain having made my own 4 tube headers, fun but a lot of work. But the look cool and lets hope work great when finished.
Paul Buxe
Panoz GTRO-0042 LS2 gone but not forgotten
Miata Chump Car
Mustang GT
Porsche Boxter (wife's ride)
Chev Suburban trailer hauler
Factory 5 Cobra Roadster, 392 stroker
You have to grow older, but you don't have to grow up
Old 11-15-2010, 05:09 AM
tccoupe tccoupe is offline
Looks very familiar. I built a set of headers for my series car last winter. Set it up with 32" primaries. Getting the length to within 1/2" +- is a pain. I would recommend you fit the collector and stitch weld the joints so they won't move. You'll have to remove the pipes to weld them. If you don't have a strong enough weld when you fit up, the pipes will move. I painted the pipes and collector while off the car. Assembled the pipes and collector on the car and welded the collector & pipes. I also installed header wrap, makes a big difference for in car heat. Good luck
bruce
Old 11-15-2010, 06:47 AM
Panoz26's Avatar
Panoz26 Panoz26 is offline
Looking great Eric! let me know when you want help, I am bored..
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 11-15-2010, 10:04 AM
Kel,
No problem with the wait, I am in the process of renewing and upgrading my motor- a winter project.
Eric,
Your headers are way cool (like all of your mods). I forgot to give them some love because they just don't fit my SBF!
Once you get them built, you ought to build some fixtures and make them for sale. I have this feeling there is going to be a growing market for the LS conversion!
If you run into any issues on welding the tubes, you might want to consider individual cylinder flanges (just cut them) and slip fit collectors. Would also make doing the fixtures easier. Are you going out both sides of the car or out the passenger side with your system?
Mike
Old 11-15-2010, 05:37 PM
Dawgfan Dawgfan is offline
Better coat those headers. It will get hotter than you think. You will also have to worry abou the sound. I bust the sound at Road Atlanta every time I run SCCA @ 106. I am running 3" pipes out the side. I would suggest trying to send the pipes out the right side. Gary Jones has the right idea I just have the money to do it right now. I must say that it will help the car a lot.
Old 11-15-2010, 07:56 PM
Thanks guys, I do plan to coat them and also header wrap them to help with heat...
The heads are going out Going to go out each side like before. Not going to try and takle that project!
Already working on. Jig to replicate, Devin is already bugging me to make another set and I haven't Sven finished the first set yet. Lol
Old 11-15-2010, 08:38 PM
Paul Buxe's Avatar
Speedway makes a 4 into 1 collector that incorporates 4~5 inch inlet pipes that lets you just slip the inlet pips over your header end tubes, making the 4 into 1 collector welding and slick install. I did that on my headers and it helped fixture the collector end of the headers.
Paul Buxe
Miata Chump Car
Mustang GT
it has begun ac427cpe MR2/MR-S 13 09-07-2003 05:54 AM
ThE Transformation has begun..... Posey88cvic4dr '88 - '91 Civic | CRX | Wagon | Shuttlee 5 08-05-2003 02:42 PM
Impreza WRX STi Project has begun! freelunch Car Modeling 4 02-04-2003 12:06 AM
It has begun. darkness Car Modeling 1 01-06-2003 02:56 PM
Retaliation has begun igor@af Politics, Investments & Current Affairs 16 10-10-2001 02:52 PM
