Old 11-13-2010, 11:18 AM
funiwant funiwant is offline
97 lesabre code p1870
when on highway or interstate the car will shudder intermittently, usually after being driven about 20 miles it will start, check engine light doesn't always come on but when it does, code p1870 comes up, i have just changed the fluid and filter, it isn't as bad as it was but is still doing it, is the converter bad or is there something else i can try? thanks
Old 11-13-2010, 04:00 PM
maxwedge maxwedge is offline
A990 racer
Re: 97 lesabre code p1870
The most common reason is the bore in the valve body for the TCC valve wears and causes the tcc to slip, but there are other causes also, if you do a site and google search there is a lot of info out there on this common GM code.
The Following User Says Thank You to maxwedge For This Useful Post:
funiwant (12-19-2011)
Code P1870 skynyrd7569 Grand Prix 2 10-09-2004 03:12 PM
Hard shifting problem - error code P1870 biglagoon9 C/K 5 08-25-2004 12:23 AM
code p1870 come's on 60 to 65 mph lordgalla Grand AM 0 07-11-2004 10:20 AM
98 5.7L, Code P1870 Oilpig C/K 0 07-07-2004 09:21 AM
Tags
1997 , converter , p1870 , shudder , transmission
