Old 11-12-2010, 09:45 PM
GregGP GregGP is offline
Fog Lights
Does anyone know a good (safe) way to keep the fog lights on with the headlights on a 2002 Grand AM SE?
Old 11-12-2010, 09:58 PM
thephantom1492 thephantom1492 is offline
Re: Fog Lights
just turn them on?
Old 11-13-2010, 12:06 AM
Re: Fog Lights
Yes. I would like to be able to keep them on when I switch from low beams to high beams. Any ideas?
Old 11-24-2010, 05:43 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Fog Lights
i have heard on other GA sites it can be done.
I personally havnt looked into it, and probly wouldnt do the hack.
If you check into disabling your DRL's you can turn your fogs on & off just with your parking lights on.
Which the other site has the DRL and Fog hack... I think, pm me for more details if interested.
1999 Grand Am SS 3.4 OHV
Old 11-24-2010, 06:13 PM
ctwright ctwright is offline
Re: Fog Lights
this is a very simple fix, if you only want them on with your high beams on. and you said a safe way which means you don't want them all tied into the same circuit. use a 12 volt relay with one set of normally open contacts, this relay will have four terminals, 2 of them are each side of the coil inside, the other 2 will be the normally open contacts which close when the coil is energized(creating an electromagnet). make sure the relay has proper current rating for the fog light circuit. Run one side of the coil to ground, the other to your high beam circuit, so the coil is energized with high beams on. you'll have to leave you switch on for the fog lamps. just break the fog light circuit somewhere and hook up to the normally open contacts on the coil. This way the only thing you are adding to your high beam circuit is a relay which won't draw much current, and you are using the same existing separate circuit for the fog lamps.
Old 11-24-2010, 06:34 PM
Re: Fog Lights
its way easier than that ctwright. I believe just a jumper or two for this model GA.
Old 11-24-2010, 06:59 PM
Re: Fog Lights
i'm not even familiar with the wiring of that vehicle, i'm just giving a general example of how to control one circuit with another, may even find that useful in another application
Old 01-23-2012, 04:35 PM
TheCarNoob's Avatar
TheCarNoob TheCarNoob is offline
Re: Fog Lights
Doesn't the 02' have a fog light switch like the 05'?
Fog lights not working misguru Cherokee 1 12-31-2009 01:55 PM
Fog lights fogging up Denver1911 Ranger | Courier 5 08-26-2008 10:06 PM
Fog Light Relay rewiring for fogs on... Shelbyscarab Contour 4 06-23-2006 07:45 AM
fog light button (is it supposed to light up all the time?) dmorlow Aurora 5 09-11-2004 09:08 PM
Bumper Light to Fog Light Conversion jajimo Accord/TSX/Accord Hybrid 1 12-25-2003 11:25 PM
