Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 11-12-2010, 07:50 PM
buymeaboat buymeaboat is offline
Corvette not cranking when turning key
Hey guys, I just broke into the Vette world today when I bought a 78 L-82. When you turn the key, no power goes to the starter. I know of the anti-theft control and she does have a new solenoid. Any help would be sweet!...Mike in Ocklawaha FL
Old 11-13-2010, 09:01 AM
MrPbody MrPbody is offline
AF -Advisor
Re: Corvette not cranking when turning key
Could be a number of things. Neutral safety switch if auto trans, clutch interlock switch if manual, is where I would start. Make sure all your connections are clean and tight. Corvettes are notorious for "ground" problems due to the 'glas body. Also be certain the correct leads are attached at the correct terminals on the solenoid. A factory wiring diagram can be of immense "help" here. Jim
Old 11-13-2010, 01:14 PM
mcmalloy mcmalloy is offline
if its a auto try it in nutrel , if its a standard jumper the purple and yellow wires to bypass the clucth switch
Turn key and nothing. no dash lights or response from the key turn at all. grrrtyson Cherokee 3 04-26-2010 12:12 PM
2001 cavalier check engine light does not illuminate when ignition key is turns san_da_man Cavalier 2 03-16-2007 10:14 AM
97 aurora delayed start when turning key jvepp Aurora 11 12-22-2006 08:36 AM
02 Cavalier No power, rapid clicking when turning key merrittjr Cavalier Problem Diagnosis 15 07-18-2006 12:22 PM
94 Astro - Nothing when turn key. HELP! AstroDog M Bodies 6 12-10-2003 08:39 PM
