Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 11-12-2010, 06:54 PM
venturenot venturenot is offline
PO 507 Code High Idle
Ok, here's yet another problem. I am getting a PO 507 - high idle- code. All of the sudden car will idle at high speed and feel like it is off to the races, and cruise control is off. Is this a common symptom of a bad IAC valve? Even though cruise control is off should I unplug the cruise control module to be sure that it is not involved? Throttle body is clean, and plates seem to open and close with no problem. Should I put a little house hold oil on the corner of the hinges just to be sure? What is the easiest way to detect a vacuum leak?
Van has 204,000 miles on it and I purchased it at 102,000 miles with a long block engine replacement @ 162,000 miles.
Old 11-14-2010, 03:46 PM
lesterl's Avatar
lesterl lesterl is offline
Re: PO 507 Code High Idle
No oil on the throttle.
Check the linkage for binding, both on the throttle and the cruise.
Unplug the Cruise.
Check for vac leaks with some carb cleaner engine running, spray around gaskets and seals of intake.
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 11-21-2010, 10:07 PM
Checked everything and still same problem. Changed the Idle Air Control valve and and that was the trick, everything is OK and running fine. Only now the car idles at only at 650 rpm. When replacing the valve I didn't have a tape measurer to get the proper extension. I just extended the cone to match the old IAC valves length. Does the length really make that much difference. Should I go back and make sure that is extended no more than suggested 1 1/8 length?
Old 11-22-2010, 10:23 AM
merc81 merc81 is offline
650 is normal idle. Does it pick up when you switch on the ac clutch? It should move to 800 or so then.
Old 11-23-2010, 07:41 PM
Yes, it picks up to about 800. I guess everything is OK.
Please help me I am getting a very high idle and a po441 code Brian.crum Problem Diagnosis 1 02-26-2008 09:53 PM
high idle po 507 beer-b-q Rodeo | Passport | MU 1 10-18-2007 07:03 PM
very high idle when in gear plus code 22 big9er Blazer 2 05-04-2005 12:19 AM
blazer s10 high idle ...have codes chriskrebs Blazer 30 04-21-2005 04:09 PM
keep getting SES 507 code giffholmes Park Avenue 5 12-16-2003 09:28 PM
