| WIP - Street Post topics for any "Works In Progress" street vehicles projects in this sub-forum. |
VW Golf MK1 Imai 1/24 Slotcar/resin project
Hi i am new here, my english is not so good, but wil be better after a while. I was bitten by the 1/24 slotcarvirus a couple of years ago.
The blue glof was build in the early 90's as a static model, a while ago i put a slotcar chassis under it so i could drive it. From then on i dicided to build more like this: ![]() ![]() I found two more Imai's, it would be a great idea to copy them in resin because they are a rare item these days. I did make a mold of a MK2 before, also MK2 bumpers i made for an MK1 project. ![]() I only have to make the rear one wider to fit the MK2 later on ![]() ![]() ![]() ![]() ![]() ![]() ![]() Made deeper panelines ![]() ![]() ![]() Filled the holes ![]() ![]() Ugly side flashers disapeard
Re: VW Golf MK1 Imai 1/24 Slotcar/resin project
Made a better grill and brake cooling holes
![]() ![]() ![]() The resin copies will have led's in the front ![]() ![]() Pe Fuelcap ![]() Sportmirror borrowed from a fujimi M3 ![]()
Audi doorhandles
![]() Rear spoiler ![]() Did some taillights in clear resin: ![]() Made a hole under the bumper for better exhaust fitting ![]() ![]() ![]() ![]() ![]() ![]() I was missing sideskirts.... |
So i put sideskirts on it.
![]() ![]() Actually the RTV was out of date, so it become to thick for casting. Instead of throw it away i was making the best out of it. The result was not very well, like i expected. The copy's has bubbles,corners are missing,... however i used the same workingflow as i did the MK2. It was trying worth it. I have a couple of usefull copy's now + made a new mold however de RTV of that one is the same lot as the first ![]() A little much sanding job ![]() ![]() ![]() and more primer sanding ![]() ![]() But hey, there is a light that shines at the tunnels end ![]() ![]() To be continued... Grts Peter |
That is WAY COOL! I might have to get one of those bodies from you once you get the mold/resin straightened out.
Disturbed Angel, very nice job! It's a real work!
Could you describe which transparent resin did you use and how did you make the rear-lights? Thanks! |
Very interesting project.
Well, you will read it here when it's all ready. |
I used a RTV silicone single mold (white), just the same i used for the body. The resin is crystal resin from GEDEO you have to mix it 2/1 with the hardner. Just have to need a scale who's fine enough, you need one with milligrams because when its not the right ratio 2/1 it will result that the resin will not hardens out and it remains soft, even 6 months later. Believe me, it happened once to me since then i have a pocket scale.Then you cast smoothly the mixture into the mold to avoid bubbles. let it harden out for at least 2 days, remove it from the mold and let it dry for one more day. Done ! You can also mix the resin with tamiya acrylic smoke X-19 for smoked lights, or clear red, ...
This is awesome work, I couldn't stop looking at this!
or 2010 QMHE Intermediate Silver - Mini Cooper S 2010 QMHE Intermediate Bronze - 37' Delivery 2011 QMHE Intermediate Silver - Panzer Tank 2011 QMHE Imtermediate Bronze - McLaren M8B |
I like the idea of the little clear boxes for your mold boxes. I bet it makes the casting process super easy.
Yup, keep clear from dust, easy to put away.
More primer & putty hopefully one of the last times on this one.
My idea was to paint it with some createx pearl white, but i'm not ready yet to use createx, it seems not so easy to use with my airbrush (badger) need to practice more first with createx. ![]() ![]() ![]() ![]() Grts Peter Last edited by Disturbed Angel; 11-19-2010 at 03:51 PM. Reason: space |
I came to my (preliminary) putty /sanding limits
I found it enough for now, although I'm not 100% satisfied with the result, my limit is reached. Time for colors ! Humbrol Primer was used, so i was bound to humbrol for all safety. First tought was ferrari red, but ik became 99 lemon, it's a matt color so varnish invites itself. Another strange thing... i can not take a picture with the color visible as it is for real ![]() ![]() ![]() ![]() ![]() To be continued Grts Peter |
