Go Back   Automotive Forums Car Chat > Dodge > Dakota
Old 11-11-2010, 03:34 PM
mlambert40 mlambert40 is offline
99 Dakota heater issue...
I own a 99 dodge dakot 5.2 4x4 and I am having an issue with my heat. When the truck is idling, it blows out luke warm air even when the truck is at temp. But when I increase the idle, the heat temp instantly increases... is this normal or what is possibly the problem. I have flushed the heater core twice in the last month and both times seemed to have helpd but not totally fix the issue. I have also been burping the system of the last few days to make sure there is no air in the system.
Thanks!!
Old 11-15-2010, 07:25 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 99 Dakota heater issue...
check your thermostat, make sure it's the proper heat range, factory recommends 192 F thermostats but there are some as low as 160.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 11-23-2010, 03:33 PM
I replaced my thermostat to a 192, and am still having the mediocre heat.... any help is greatly appreciated!!!
Old 11-30-2010, 08:27 AM
sad to say, you're going to need a new heater core. I know I need to replace mine on my '95 Dakota V6, it's doing the exact same thing as your truck. Good thing is, it only costs $40 for the core, bad thing is you'll have to take the dash out & have to discharge your freon to replace it.
Old 01-11-2011, 05:11 PM
davida6302 davida6302 is offline
Hello, I had this issue with my wifes 03 Buick. I added antifreeze in the reservior and it fixed it, obviously not enough in the system, hope this helps.
'89 Dakota heater blower quit working.... davemc53 Dakota 2 03-02-2007 10:07 AM
1999 Dakota Heater will not get hot SteveArt Dakota 6 12-09-2005 01:15 AM
97 Dakota Heater Core Replacement NEED HELP!!! beyondspecs Dakota 1 06-22-2005 04:12 AM
93 Dakota Heater Fan jgreen31 Dakota 2 06-12-2005 07:54 PM
1989 dodge dakota heater/ a/c sam moore Dakota 1 12-23-2004 08:27 PM
