Old 11-10-2010, 07:34 PM
jsimmoms jsimmoms is offline
96 3.8 Hard Starting/Rough Running Battery Light On
I'm putting my van back on the road after sitting for 1yr and it is hard to start then once it starts it runs rough. Once it runs for a few minutes it will smooth out, but if I shut it off then restart it , it does the same thing. I replaced the fuel filter and checked the fuel pressure which looks strange. It is KOEO 20lbs which I know is low, but when I get it started it bounces from 25-35. I pulled the vacuum line off the regulator and it made no difference. Fuel pump bad? The other problem is with the battery light, when I was letting it run it would come on then go out. I got my meter out and started checking things and I have 14.3-6 when running, 12.3 when off. I charged the battery before I put it back in so I wouldn't kill the alternator. Any ideas. Thanks
Old 11-11-2010, 11:14 AM
wiswind wiswind is offline
Re: 96 3.8 Hard Starting/Rough Running Battery Light On
I would check and clean all the battery connections and verify good connection to the chasis.
Otherwise, you may need a new battery.
The battery light is an indication that a voltage is being sensed as too low, which only takes 1 poor connection, or defective battery, or defective alternator.
Low voltage will cause the engine to run rough, can cause fuel pump issues, etc.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
1996 3.8 hard starting fire129 Cougar 1 01-23-2010 08:38 PM
cold mornings: hard to start, rough running, low idle, stalls out sad-lumina-owner Lumina 15 11-09-2008 12:58 AM
1991 z34 3.4 hard start/runs rough newtec04 Lumina 2 08-20-2005 10:20 PM
Hard starting and runs rough on humid days bonz32 Lumina 1 04-06-2004 08:17 PM
3.8 HARD Cold starts..Need Help please O.P Bonneville 10 03-21-2004 05:27 PM
