Old 11-10-2010, 05:18 PM
boatbuster boatbuster is offline
P0137 code
When it's not one thing on this van it's another. On my way to work this morning my check engine light came on, plugged her in and found a P0137 code showing 02 sensor circuit low, voltage bank 1 sensor. Would this indicate a broken wire or corrosion or??? I am guessing bank 1 would be the left (driver) side????? I cleared the code but would like to stop it from coming back.
Thanks for any help
Old 11-11-2010, 09:57 PM
Blue Bowtie's Avatar
Registered Offender
Re: P0137 code
That would be the left (driver side) upstream sensor. The code indicates a signal below the bias voltage.
If you read the voltage in the circuit at the PCM terminals or back-probe the sensor connector and get zero volts it could be a shorted sensor. If disconnecting the sensor causes the circuit voltage to rise to 350-450 mV it is likely a shorted sensor. If disconnecting the sensor causes no rise in circuit voltage look for shorted wiring or an open circuit at the PCM. Moisture and corrosion in connectors can shunt the signal the same way.
If you are lucky/careful, you can exchange the two sensors and see if the problem moves with the sensor or remains with the wire harness.
code 24 zetan Corolla/Matrix/Voltz 2 04-10-2009 09:59 AM
trouble codes danielgast46 F Series 6 04-06-2009 07:06 AM
1993 Acura integra Stereo Code Omega-Factor Interior | Audio | Security 1 03-25-2009 07:08 PM
01 Sport Trac Door Code??? levi.calhoun Explorer | Explorer Sport Trac 1 03-23-2009 10:09 PM
P0137 Code - 2002 Dodge Durango 4.7L bennymetal Durango 2 07-30-2007 09:38 AM
