Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 11-09-2010, 07:37 PM
Towroma Towroma is offline
Question 94 Roadmaster OBD 1 ALDL connector A-B jump runs fan
Trying to access OBD I codes. Jumping A and B does not cause SERVICE ENGINE light to flash. When ignition is turned on, the cooling fan runs. What could this mean?
Last edited by Towroma; 11-10-2010 at 05:38 PM. Reason: Need better description in post
Old 11-09-2010, 07:50 PM
maxwedge maxwedge is offline
A990 racer
Re: 94 Roadmaster ALDL A/B jumper runs fan
Could be obd 1.5 which needs a scanner or the wrong terminals are jumped.
Old 11-10-2010, 04:59 PM
The underdash connector has the standard 12-pin OBD 1 configuration. I jumped the two rightmost pins on the top row. The SERVICE ENGINE light flashes once very briefly, then nothing more. The cooling fan (only one electric fan with tow package) runs continually with the pins jumped. I'm baffled.
Old 11-11-2010, 09:23 PM
Blue Bowtie's Avatar
Registered Offender
Both conditions are correct. The 1994 and 95 B- and D-Bodies require a scanner to access stored codes. The old method of jumpering the ALDL to force the MIL to strobe out the stored codes is not applicable. My '94 Impala acts exactly the same way.
Also, even with the older ECMs, once in diagnostic mode (ALDL jumpered) the electric cooling fan will operate. That is normal all the way back to my 1986 Trans Am, and probably some even older ECMs with the 8K PROMs and no CALPAK.
Further, many places which offer free code scanning (like Auto Zone and other chains) will be unable to scan your vehicle since it is not truly OBD-II. A Tech II, Snap On MT2500, and some Actron scanners will be able to access the ECM. Some PC software programs with a proper adapter can also access the ECM data.
My 92 Roadmaster is hard to start, runs badly reggieh Roadmaster 5 04-16-2010 12:32 AM
HELP! 98 Jetta-Fan keeps running after engine is off Sunshine17 '97 - '03 3 01-17-2010 01:47 PM
Fan always runs when the engine is running boomboom SC/SL/SW 8 09-16-2009 02:06 PM
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 12:05 PM
Engine Fans Not Running Whilst Engine Running? scatz Laguna/Laguna II 0 07-07-2007 12:10 PM
