Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-08-2010, 02:44 PM
LEM LEM is offline
'08 4Runner AWD V8 Propeller Shaft Lube
I noticed in the maintenance manual a recommendation to lubricate the propeller shafts every 10,00 miles or so if you're towing, so I decided to look into this.
First off I had to figureout what they menat by propeller shafts: these are the driveshafts from the transfer case to the front and rear differentials. The lubricated components are the universal joints and the yokes.
So I bought a tube of Mobil 1 grease, put the vehicle up on jackstands and performed the job. Took all of 45 minutes start to finish and the only problem was accessing the zerk fitting on the u-joint on the front shaft.
So I'm good for another 10,000 miles or whenever I feel like crawling underneath it again.
I found a couple of good posts on other forums that really helped. If you'r interested, just reply to this post and I'll put them up...I guess I'm allowed to promote other sites on this forum, even if they are competitors, right?
-1990 Mustang LX 5.0L 5-Speed All Stock! except the stereo...
-2005 Yamaha V-Star 1100 Custom
-2008 Toyota 4Runner Ltd 4.7L AWD
-2019 Subaru Ascent (the wife's)
Old 11-16-2010, 08:24 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: '08 4Runner AWD V8 Propeller Shaft Lube
You can post links to other sites if they are direct links to relevant discussions. You shouldn't post links to the front page or log-in page (etc) of competitor's sites. Then it appears you are promoting the site instead of assisting in a discussion.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
propeller shaft spline grease? 1991Blazer4x4 Blazer 0 12-10-2004 04:46 PM
Propeller Shaft Maint. for 03 4x4 KAMXMAN Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 2 08-04-2004 08:57 AM
Driveshaft AKA Propeller Shaft metaphysiKal 3000GT/Stealth 0 07-21-2004 02:02 AM
