Old 11-08-2010, 09:32 AM
yaryar yaryar is offline
Transmission problem???
Hey all, been a while since my last problem, but now I'm having a strange, potentially expensive issue. Background - My truck is a 1995 Silverado 1500, 5.7L V8, automatic trans. This morning all was fine on the way to work, until I came to a stop. When accelerating after the stop, the engine went to 2500RPM before shifting to 2nd gear, then 2500RPM to 3rd gear, and the same to 4th gear. Continued doing this every time I came to a stop, then tried to get back up to speed(60MPH). I figured transmission finally went(as I have 172K miles on it), but when I shifted into park, instead of the usual 700RPM, then engine was running at 1000RPM, and not a steady idle either. So I shut the truck off, and start it up about 10 minutes later, and it's running fine again!!! Any ideas on what this problem could be??? Any help is greatly appreciated!!
Old 11-08-2010, 06:15 PM
transman618 transman618 is offline
Re: Transmission problem???
TPS possibly. I would have it scanned to be sure.
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
Old 11-09-2010, 03:10 PM
Update, I was able to read the fault codes and came up with:
22, 28, 32, 54, and 59. Code 22 points to the throttle position sensor, as the above poster recommended, so I'll change that this weekend, and then see if the other fault codes clear up.
Old 11-09-2010, 08:59 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Repair/replace the TPS then you have to clear the stored codes. Once a fault is detected, whether it was 2 minutes or 2 years ago, it is stored in the ECM until it is cleared. Erasing them and then checking for new codes will help you find out what your current problem is.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
All years T&C or Caravan. reassembling transmission problem shiftnd Caravan | Voyager 1 08-28-2010 03:58 AM
99 Camry LE problems johnwuy Camry/Camry Hybrid/Vista 4 09-16-2009 04:05 PM
92 S-10 Transmission AK47 SRH420 Performance 0 04-06-2009 07:21 PM
Changing Transmission mkcody88 Accord/TSX/Accord Hybrid 2 04-05-2009 01:50 PM
2003 s10 transmission problems burk4200 Problem Diagnosis 6 03-30-2009 07:07 PM
