Old 11-07-2010, 02:29 PM
eccs19 eccs19 is offline
1998 Sunfire engine codes
My friend's sunfire has a few codes in it, and I've pulled them out. Looking for tips on what may be causing these codes.
P0442 - EVAP Emission Control System Leak (small)
P0342 - Camshaft Position Sensor A - Bank 1 Circuit low input
P0125 - Closed Loop Fuel CTRL Insufficient Coolant Temp
We suspect the 442 may have been caused by a fuel cap, and it has been replaced, but the others are a bit more worry some. The engine is a 2200. The car runs great, so I'm not sure if the others are anything to worry about or not, or what we would need to check. Any tips?
Old 11-07-2010, 02:40 PM
danielsatur danielsatur is offline
Re: 1998 Sunfire engine codes
P0442 - You are probably right with gas cap, or there's a bad rubber hose somewhere.
P0342 - Clean electrical connector going to the cam sensor, and use dielectric grease.
P0125 - It's taking too long for the coolant to get normal operating Temp.
Suspect-
1) Shortage of coolant
2) Bad thermostat
3) Is the electric fan running during warmup, because of a stuck on Relay?
Old 11-07-2010, 02:44 PM
Suspect-
2) Bad thermostat
I'll have him check the fan. I was thinking the thermostat may need to be changed. Probably the easiest thing to try first.
For the P0342, where is the sensor on this car? Easy to get to? Cleaning is something that sounds like it should be easy. (we've all had "easy" jobs that turn into nightmares)
Sunfire is stalling at idle: 1998 Sunfire 2.4L Twin Cam Engine/Automatic Transmission mpre General Discussions 3 06-11-2009 07:18 AM
1998 cavalier engine code P0742 jsmith1973 Cavalier Problem Diagnosis 1 04-30-2009 09:17 PM
1998 318i Engine Code dermin 3 Series 1 09-17-2005 12:12 PM
1998 Sunfire 2.2l code PO301 misfire cyl. 1 phillipgr General Discussions 6 09-04-2005 08:27 AM
1998 sunfire 2.4 quad engine borderqueen General Discussions 10 08-23-2004 09:15 PM
