Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 11-07-2010, 11:04 AM
lo6202 lo6202 is offline
PO401 OBD-II trouble code
HI
2000 ranger 3.0 v6, last year engine light came on. Advance auto did code check PO401. Removed EGR valve and tube found no carbon buildup or clog so i replaced DPFE sensor and no problem for 8 or 9 months. Engine light is back on with the same PO401 code. Could use some advice on what to do next.
Thanks
Old 11-07-2010, 01:10 PM
danielsatur danielsatur is offline
Re: PO401 OBD-II trouble code
Need to take off the throttle body, and clean both the throttle body, and EGR gase
passages. The Emission gunk will plug your Egr passages, and contaminate your throttle body.
Also see http://www.ideabuyer.com/ipavail/acm...issions-filter
Old 11-08-2010, 07:06 AM
Davescort97 Davescort97 is offline
Escort guy
I'd replace the EGR valve. PO401 is insufficient flow EGR Valve. If the passages in the throttle body were plugged up the computer would sense insufficient flow and would over compensate by PO 402 Excessive flow EGR valve. I had this happen on my Escort. Replaced the EGR. Everything is fine now.
Old 01-03-2011, 12:12 AM
markdpro markdpro is offline
Smile Re: PO401 OBD-II trouble code
There are many possibilities here.
1st check vacuum lines to ERG from EGR solenoid and then to manifold vacuum. Look for holes cracks or loose fittings.
2nd check hoses to DPFE valve.
3rd clean EGR tube
4th check flow thro DPFE and solenoid use manual to see how
5th check the solenoid for continuity
6th pull vac line from EGR while idling engine should stall. If not consider replacing 1 egr control solenoid 2 DPFE sensor 3 egr valve itself.
It took me 2 years to find out the check engine cause was the EGR solenoid
Meaning of OBD II Trouble Coades medic5351 Celebrity 1 01-22-2008 08:24 PM
OBD II trouble code Mic1980 1st Gen 95-99 0 03-12-2007 09:18 AM
Found a full list of OBD II Trouble Codes Johnny Mullet Mustang Problem Diagnosis 0 08-15-2006 10:59 AM
95 Nissan Maxima GXE OBD-II Error Code ausikdar Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 3 12-01-2003 03:45 PM
OBD II Diagnostic Codes in Gen 4 Camry yotatechie04 Camry/Camry Hybrid/Vista 0 11-27-2003 07:29 PM
