Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 11-06-2010, 01:57 PM
bluepassat99 bluepassat99 is offline
99 1.8T won't start
I am problem starting my 99 1.8T. The fan in front of the engine rotates when I turned the key and it makes the noise but I don't think the engine turns over.
I was having a cylinder 2 misfire and I checked the ignition control module. Readings for the 4 pins are 3.5, open, 3.5, 3.5 (cylinder 1, 2, 3, 4). I connected the cylinder 1 spark plug wire to cylinder 2 by mistake but the engine started and ran. After I disconnected the battery and swapped the ignition coils, I haven't been able to start the engine.
What could be the possible cause? The ignition control module is totally bad? Something went wrong because I disconnected the battery?
Any help is greatly appreciated.
1996 Jeep Cherokee Won't Start mocojpo2003 Cherokee 16 09-14-2011 03:39 PM
99 Saturn SL Won't Start! turtleisland SC/SL/SW 5 08-13-2009 09:52 PM
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 03:20 PM
99 passat 1.8T won't start green_vw_dude Passat 1 04-11-2006 12:24 AM
2002 Jetta 1.8T - won't start styman19 '97 - '03 2 02-25-2005 10:03 PM
