Old 11-06-2010, 12:46 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
what is this?
so i went to roll my window down yesterday and it just fell into the door. i took the door apart and found the problem.. i also found this and was wodnering what it was... the square patch type thing inside the door.. theres the first one, then another one deeper in the door, with like an oval thing half in it. is this exactly what looks like, a patch?? from a body shop fixing body damage, or is it somethiing else? i went to peel it off for about 2 seconds then had second thoughts...
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 11-07-2010, 06:22 AM
snshddog snshddog is offline
Re: what is this?
The factory puts those in various places to reduce noise. Stops the body panels from rattling and wobbling. Yes it does work. There should be more of them in the trunk against the side body panel. If you remove it it won't add much noise but it doesnt hurt to leave it there unless you are in an area bad for rust as rarely moisture can get at the edges and promote rust under it. That too is rare.
Old 11-07-2010, 09:06 AM
Re: what is this?
thank you for the response. noise reduction is what everyone else ive asked has said too
Old 11-07-2010, 09:17 AM
Blue Bowtie's Avatar
Registered Offender
Re: what is this?
A more infamous example of that is found on the new Camaro. As an afterthought, weights were "glued" to the brake calipers to deaden the harmonics and prevent chatter. It seems that engineering is a lost science.
whats this on Eibach's site? JasIzBac Suspension 6 02-25-2002 10:16 PM
Not sure what this is, need Help imphatr Engineering/ Technical 5 02-19-2002 04:17 PM
Anyone know what this is? A380Driver General 9 12-10-2001 08:49 PM
whats this thing for? YellowMaranello Engineering/ Technical 4 09-29-2001 10:58 AM
