Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 11-06-2010, 11:52 AM
pmwibif pmwibif is offline
high idle in park
98 trans sport 3.4
idles up to 3k in park, and sometimes 1500 in gear. sometimes it doesn't idle high at all. assuming it's a sensor, should i start with the tps or iac? thanks in advance
Old 11-08-2010, 01:15 PM
rkvons's Avatar
rkvons rkvons is offline
Re: high idle in park
Originally Posted by pmwibif View Post
98 trans sport 3.4
I would do the TPS first. Are there any codes set?
Old 11-08-2010, 01:28 PM
danielsatur danielsatur is offline
Start with a visual inspection.
1) clean the TPS and IAC controls, electrical connectors, and use dieletric grease for connector electrical connections.
2) Consider a smoke test done for unmeterd air leaks, because she's running lean.
Suspect - Bad plastic, rubber, or seals from the EGR, or PCV system.
Old 11-08-2010, 06:38 PM
already replaced pcv valve and elbow because they were cracked. engine light isn't on, i might be blindly assuming the light works. is there a self-diagnostic procedure on this? i will clean the connectors first, thanks for the tip
2.7 high and or rough idle hauck Intrepid 6 02-25-2012 12:46 PM
High idle pappyam Problem Diagnosis 34 12-06-2010 09:31 AM
2002 explorer v8 4wd eb high idle and shifting problem BAKERCONTAINER Explorer | Explorer Sport Trac 0 02-03-2010 02:22 PM
1988 cherokee 4.0L hgih idle/engine tick pstoric83 Cherokee 9 08-06-2009 12:18 AM
1992 High idle in park and rough idle in gears warptre Explorer | Explorer Sport Trac 8 04-11-2009 09:34 AM
