Old 11-05-2010, 10:17 PM
glink glink is offline
Unhappy Transmission problem
1996 grand voyager 3.0l 3 speed. The transmission gave up so i installed a used one. Everything was shifting fine but once in a while it didn't want to go like it was going to stall. it did this for half a block nad then everything was fine for about 10 klms and it does it again Service engine light came on so we scanned it and gave a code of p0743.change the solenoid and now it dosn't want to switch out of first gear any ideas.
thansks
Old 11-07-2010, 06:57 PM
plymouthsrock plymouthsrock is offline
Re: Transmission problem
Did you clear the code after the repair? If so, are you still getting the code? If so, check the circuit between the TCM and the TCC solenoid. The fault indicates either an open or short in this circuit.
Old 11-09-2010, 03:51 PM
mikefaster mikefaster is offline
Sometimes, while doing a tranny swap on an older Chrysler vehicle, dirt gets into the electrical plugs... Clean them out and then put some dielectric grease on them.. Also, sometimes the input shaft sensor or the output shaft sensor plugs get screwed up... they make replacement repair plugs for them; if you pull on the wire instead of the black plastic plug, then pins can come out of the ends... If you are ONLY in first gear, I would suspect the input/output shaft sensors/plugs... You may want to try to use your old sensors and try them as well... But you should be getting OTHER codes... That code is for the TCC solenoid... Use a scanner that shows "pending" codes as well... Or just drive it for a few miles, and the code should become a "hard" code...
Make sure any grounds are where they should be as well...
Mike
Old 11-09-2010, 04:47 PM
jpb53 jpb53 is offline
TCC circuit is very simple circuit. Possibly the govenor tubes are not propery seated in the housing when you put the valve body back in the trans or the throttle pressure linkage is off or binding, Initial problem sounds like a sticking govenor.
Old 11-09-2010, 05:02 PM
I didn't look that it was a 3 speed... For get my last post...
Yeah, since you dropped the valve body, the governor tubes must not be aligned right and not in their respective holes...
Mike
Old 12-31-2013, 05:57 AM
tcpaffe tcpaffe is offline
Send a message via AIM to tcpaffe
well the transmition from a 3.3 bolt up to a 3.0
Old 12-31-2013, 07:03 AM
No. The 3.0 has a radiator hose running through the top of the transmission and the torque converter is physically smaller...
Alarmed by website highlighting Honda Odyssey Transmission Problems LibertyLoudSpeaker Odyssey 1 07-09-2010 03:03 PM
2003 GMC Sierra 1500 5.3 Transmission Problem kkaupang Sierra 1 05-19-2010 09:58 PM
1994 Prizm possible transmission problem theginchico Nova | Prizm | Spectrum | Sprint 0 04-11-2010 12:52 PM
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
Transmission Problem SeanCL Cobalt 3 09-15-2009 08:16 AM
