Old 11-05-2010, 12:42 PM
xs03mich xs03mich is offline
Vibration 01 Park Avenue
!09,000 miles car shakes thru the steering wheel and the seat on highway driving from appox 60 mph and higher. Needed new tires anyways thought it was tire balance problem. Put on 4 new tires, road force balanced all four still shaking. Road force agian, still shaking. So I am ruling out the tires. All front end parts are fine, rear end parts are fine. Struts have 30000 miles on them, but the strut bearings are shot. Aligment was done 12000 miles ago when I replaced the outer tie rod ends on both sides up front. Not getting any bearing noises with car on hoist and hand turning the wheels. Any ideas where to go next? I need to change the strut bearings out and do another aligment. Any thing else to look at? Just trying to get the ride back.
Old 11-05-2010, 06:59 PM
maxwedge maxwedge is offline
A990 racer
Re: Vibration 01 Park Avenue
Something is worn or out of balance, jack up the ft and run it off the ground till you feel it or don't, also have a helper look at the wheels as they spin, safely here of course, post back results.
Old 11-06-2010, 08:22 PM
Everything seems tight, right now I may be leaning to a wheel bearing up front starting to go bad. I will throw it up on the hoist next week start it up and throw her in drive! Spinning by hand I can not tell any difference. I will know more end of next week.
Old 11-06-2010, 10:50 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
It might be better to use the six/twelve o'clock rock position with the wheel off the ground. If you feel ANY movement, and I mean ANY, chances are you have a bad hub bearing. This movement is hard to see with the wheel/tire spinning!
Old 11-11-2010, 11:01 AM
Well it seems that the front end is ok as nothing is worn. Second mechanic confirms shaking in the seat and steering wheel, acts like a bad tire or out of balance. Next up....on the car tire balance. This should get me some answers. I will have it done next week.
Old 11-13-2010, 06:25 AM
Friday 11/12/10, back to tire shop. All four tire road force balanced agian. No change in driving at 70 mph. First of the week, on the car tire balance.
Old 11-15-2010, 12:22 PM
OK everything is good with the driving over 70mph. Had the tires balanced on the car. Two rears were out, one front was out, the right front they said should not of even been on the car. Rotated right front 180 degrees spin balance and rebalance on the car. OK it rides perfect now, that problem solved. I knew I was not going crazy yet! lol
Old 11-15-2010, 05:46 PM
auto trainy auto trainy is offline
Question Re: Vibration 01 Park Avenue
A quick question,is this the same place that installed and balanced the wheels in the first place? Also when you say they rotated the tire 180 degrees did they remount the tire on the rim?
Old 11-16-2010, 06:41 AM
Thanks auto trainy, yes it was a different shop that did the rebalancing. Not happy about the extra $$$ but that is the way it is.....at least now it will not drive me crazy. Yes the right front was taken off the rim rotated 180, spun balanced first then put back on the right front and reblanced on the car.
I have used this shop before with on the car balancing in the past with great results. They have balanced my gmc 6500 work truck tires before. Now if they can do something about the roads around here! lol
It looks like the road force machine at the first place needs a balance.....I will stop by the first place that sold me the tires and did the road force balances this week agian and present them with the invoice from the place that fixed thier problem.
Old 11-21-2010, 06:55 PM
82Stang 82Stang is offline
In my experience, a vibration in the steering wheel at 55 or above is almost always an out of balance tire. A balance is only as good as the person doing the balance too. Some kids will say "oh, close enough", but balancing doesn't work like that. On a side note, I have replaced the front hubs on my 99 PA 3 times per side in the last 5 years. It seems they don't make good parts anymore. Or I'm a shotty mechanic.
"When I was a kid my parents moved a lot, but I always found them."
Rodney Dangerfield
Old 11-21-2010, 09:20 PM
The thing that gets me is the shop doing the road force has been road force balancing my tires for me for years......I did not suspect a tire problem...but that was all there was left. Lets just say as I went back to the road force shop and showed them the bill from the on the car balance shop.....I just got a bunch of shoulder shrugs from them? At that point I wonder if they know thier machine is out of balance or can not balance good. I mean how many folks want their car tires road force balanced in this economy...not many. I have not received a good tire balance from a chain tire store in many years, so I went to this mom and pop place. Bottom line, first shop lost a customer but problem solved and the car will get on the car tire balancing for as long as I own it.
Old 11-21-2010, 10:15 PM
HotZ28's Avatar
AF Moderator Elite
With the same person doing the task? Any machine is only as good as it's operator!
Old 11-22-2010, 09:21 PM
Yes sir HotZ, same person, manager/owner, same machine.....all the same every time over the years......just when you think you have found the right place.
Old 01-17-2015, 07:12 AM
airborne1 airborne1 is offline
I have a 99 lesabre had the same problem for 6 years even bought new rims,put in bearings,struts,upgraded suspension system,tires road forced many times,finally the rack and pinion went out and had to put in new one,(SHAKE AND SHIMMY GONE!!!!)Don't ask me how,haven't got a clue.
1992 Park Avenue Will not start but turns over mattdavidhobby Park Avenue 5 03-18-2010 10:51 PM
1994 Park Avenue Fuse Panel diagrams? Justin2010 Park Avenue 1 01-17-2010 09:35 AM
'95 Park Ave OBDI port location? GMLoyalist Park Avenue 2 04-14-2009 12:57 AM
vibration on 94 park avenue tubaglue Park Avenue 3 04-20-2006 08:24 PM
2005 Buick Park Avenue vibration JCR62 Tires and Wheels 5 10-14-2004 07:14 PM
