Old 11-05-2010, 11:45 AM
pinhead159 pinhead159 is offline
engine oil in coolant
Hello everyone,
I have oil in the coolant of my GM 350 what does this indicate?
This engine is in a 1980 Chev C30 steep-van and is a GM replacement crate motor.
The water pump failed and it did get hot before the oil showed up in the radiator.
I am thinking a blown head gasket, cracked head or block.
Jack
Jack
1986 Pontiac Fiero Gt Fastback 2.8 V6
2-1987 Pontiac Fiero GT Fastback 2.8 V6
2002 Saturn SC-1
1958 Chevy C-10 truck
Old 11-05-2010, 08:49 PM
vgames33 vgames33 is offline
Re: engine oil in coolant
Those are pretty much the only options. At least its just oil in the coolant, not the other way around. Most likely the gasket.
Old 11-05-2010, 09:08 PM
danielsatur danielsatur is offline
You might want to try some http://www.steelseal.com ,and let us know if it works.
Old 11-05-2010, 10:22 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Are you sure its not auto transmission fluid in the radiator?
A leaking transmission cooler is a common route for oil to get in coolant.
Otherwise you may have an internal crack in the block, where an oil gallery is allowing pressurized oil into the coolant. I would not suspect a head gasket simply because there is no pressurized oil passing through it, and I cannot see drainback oil getting into a pressurized cooling system.
Old 11-05-2010, 10:34 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Mechanic in a can to the rescue..
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 11-06-2010, 04:37 PM
Some shops charge for a new head gasket repair $1200 to fix, use this $100 product for repair.
http://www.youtube.com/watch?v=3suQy44G_B0
Dropped Razor Blade in Engine wagslick 6 1 10-22-2010 09:16 PM
Getting oil out of coolant mohammedsk Accord/TSX/Accord Hybrid 7 10-12-2010 09:58 AM
Coolant reservoir has engine oil in it - dipstick has no antifreeze in the oil. Why? eeyore2123 C/K 13 02-15-2009 06:24 AM
Engine Oil/Coolant leak on the 3.1 V6 BeatnikTermite Malibu 9 12-13-2004 10:14 PM
Coolant in engine oil, need advise? unioncreek Eighty Eight 0 11-02-2004 12:48 PM
