Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-21-2003, 05:53 PM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
02 sensor
where is it? what is it? and how do I get it out to put a new one in? and how much is it?
Darrell
thegrumpysergeant.net
Old 05-21-2003, 10:32 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
O2 sensors are located in the exhaust manifold and or in the cat converter. You simply unplug one end of it and unscrew the other end from the manifold and or cat. They can get pricey. Check local junkyards or go to the source.( your local Honda dealer)
Old 05-22-2003, 03:08 AM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
new stock one like $300.. from a discout retailer of OEM acura parts
Old 05-22-2003, 09:10 AM
GSR GSR is offline
Send a message via AIM to GSR
maybe for the 0-5v wideband. it should be close to $200 from dealer or $80 from ebay. its an original ntk/ngk so same quality.
looking for a 95+ 240sx in/near D F Dub area
Old 05-22-2003, 07:26 PM
AF's #1 Bad Guy
what does it do?
Darrell
Old 05-23-2003, 12:33 AM
GSR GSR is offline
what does an an oxygen sensor do?
it measures the amount of oxygen in the exhaust gasses and sends it as a voltage signal to the ecu which constantly makes injector pulse changes to try to keep the air to fuel ratio as close to 14.7:1 as possible. 99.9% of all production vehicles use a 0-1 volt sensor. 0v beaing leanest, 1v being richest. however, 1v sensors are not linear/accurate enough to tune for high performance, thats where the wideband 0-5 volt sensors come in. you only need a regular o2 sensor replacement.
