Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '04+
Old 11-04-2010, 12:11 AM
kmears kmears is offline
2008 Jetta Wolfsburg cylinder miss fire issue
Has anyone had miss fire issues with the 2.0T?
Old 03-26-2015, 05:05 PM
eparker eparker is offline
Re: 2008 Jetta Wolfsburg cylinder miss fire issue
This is a common issue on these cars, It is most likely one of the Coil packs. You can buy a spark tester to see if one of them is bad. You will probably also have a check engine light, if you scan the code you can see which cylinder has the issue and then move the coil packs to see if the code moves. They are less than $100 for all four, on my 2010 I replaced them all twice already.
2002 miss-fire #3 cylinder macjak Econoline 3 04-05-2009 03:04 PM
87 Jetta GL Wolfsburg clayhaworth '83 - '90 1 03-22-2009 05:04 PM
97 LHS Cylinder 5 Miss Fire MaTangy23 LHS 0 05-10-2008 01:29 PM
P0302 cylinde #2 miss fire????? wmr95 Windstar 10 02-10-2008 08:43 AM
What is cylinder miss fire winhui Windstar 1 01-11-2004 06:58 PM
