Go Back   Automotive Forums Car Chat > GMC > General Discussion
Old 11-03-2010, 09:56 AM
Eddy1 Eddy1 is offline
rattling only when idoling
This may be hard to diagnose unless you hear the noise, when I first start the truck and it is at high idol, 800 rpm, it does not make the rattling noise. Once it warms up and goes down to low idol, 600 rpm, it makes a bad rattling noise, if I then put the AC on it gets worse or if I crank the steering right over either side it gets bad, if I put a bit gas to it, it also get better, its only at low Idol it does this. I thought it could be a bearing on the water pump etc,this was checked all the pulleys that are on the belt feel fine, this would not explain it going away at higher idol setting but it was checked regardless, the noise is in the front of the motor maybe even a little worse under the truck its hard to tell. Also at low idol without a belt off of it, it sounds fine, its seems to only happen when it is loaded up. This is a 95 turbo diesel suburban.
Any help would be appreciated.
No start, has spark, has fuel, only when warm? anyone? ateball7 Achieva 0 02-14-2009 08:19 PM
Toyota Tercel 1996 billowing white smoke only when humid and only on start up sarahdehart Tercel 0 04-17-2007 06:55 PM
1998 Malibu stalling when idol kevinpublic Malibu 8 09-27-2006 03:13 PM
stalls when stoping, only when gas under 1/2 wristman Accord/TSX/Accord Hybrid 1 01-05-2005 06:06 PM
rattle noise when the a/c is running and when I give the car gas? jfetz 3 Series 1 09-09-2003 01:31 PM
