Old 11-02-2010, 08:14 PM
jfl330 jfl330 is offline
IAC Question
In the process of cleaning my IAC, I had the chamber filled with carb cleaner and was using a stick to clean everything I could.
When I went to swish the carb cleaner around, my hand got wet. Further inspection found that the carb cleaner was coming out of the nickle size "cap" on the top of the IAC.
It would seem to me that this should be a sealed system and the only air in or out was through the plunger that moves back and forth under control from PCM.
I think if carb cleaner (or air) can get in through that cap that it would be a vacuum leak.
Anyone know if this "cap" should be sealed or is it some kind of vent.
Thanks.
2000 Ford Windstar SEL
119,000 miles, 3 transmissions so far
Old 11-02-2010, 09:41 PM
wiswind wiswind is offline
Re: IAC Question
I do not know for a 2000.
The IAC on my '96 was different and did not have that cap.
I looked up the IAC for a 2000 3.8L windstar and see that it is different than mine....and has that cap.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 11-05-2010, 02:54 PM
jbearden84 jbearden84 is offline
Re: IAC Question
From what I've read, the black cap is some sort of vent that contains a small filter inside. If you are going to clean the IAC, carefully pull off the cap first.
If youve already got this filter wet with cleaner, pull the cap off and let the filter dry first. From the diagram, it looks like this vent would be on the outer side of the throttle plate, so it shouldnt be a vacuum leak. I would say that its normal for cleaner to come out of this area, just take it off and dry that filter.
As a side note, i've also read that these valves are not servicable and should not be cleaned. Only replaced. But i've cleaned several.
IAC Question...misfires and more hoofan Grand Cherokee | Grand Cherokee SRT8 4 05-28-2006 03:17 PM
2000 Z24 IAC question *theone* Cavalier Problem Diagnosis 0 03-29-2006 06:19 PM
'96 Corsica 2.2L IAC Question mcrosby Corsica 2 03-15-2006 02:09 AM
IAC Question simaronde03 Windstar 9 08-17-2005 06:26 AM
another IAC question pb31 Thunderbird 3 03-08-2005 06:19 PM
