"Pass-Key" Problem
Greetings Anyone & Everyone
I have purchased a 96' Grand Am SE (2.4)for my son, however, it will crank over, but not continually run due to the security system locking up. She runs for about 2-3 seconds and shuts off; I do hear the fuel pump running though. The security light flashes, then after let sitting 10 minutes it's a constant light (tried this "reset" after suggestions from other forums). I'm stumped. I read it could be either of the following: BCM, something in the Dash Board, or anti-theft system. If you have any information, direction, literature, or input on how to override this issue it will be greatly appreciated. Any Help is greatly appreciated. Please. Thanks in advance, -TuType |
Re: "Pass-Key" Problem
Welcome to the Grand Prix forums. We can try to help out, but you may get more relevent info on the Grand am forums.
The security relearn, first make sure that you are using a GM PK3 type key, and not a key copied at wal-mart. (because they will make copied of transponder keys and send you on your way, btdt). A PK3 will be stamped on your key shank. For the relearn to work, you need to turn your ignition on, leave the car sit like that for a half hour, turn the ignition off, and immediatly back on, leave it sit for another half hour, and repeat this one more time. After the 3rd time, the car should recognize the key and start. (this is how it performs on grand prix's though. Grand am's may be different)
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
