Chevy Suburban 2003 8.1 gasoline
intermitant non start vehicle can run for days then every now and then will not start, when vehicle eventually starts its difficult to pinpoint fault sound like fuel starvation but fuel pump working need some help.
Re: Chevy Suburban 2003 8.1 gasoline
Check fuel pressure for up to par when no start.
Any security lights on or add on anti theft?
Next time it doesn't start, crawl under and tap the starter with a hammer or similar blunt object. If it starts, then the starter brushes or the contacts on the rotor are worn out and landing on a dead spot where no current can flow. The brushes are replaceable, the rotor isn't...have to replace the whole starter.
Hope this helps!
Current Garage: 2009 Honda CR-V EX 2006 Mazda 3i 2004 Chevrolet Silverado 2500HD 2003 GMC Envoy XL 2000 Honda ST1100 2000 Pontiac Sunfire Vehicle History: 2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat. |
Check the relays related to the injectors and starter. the relays are located under the hood in the engine compartment fuse center. I've hadmy truck just shut off while driving and a no crank situation subsequently. when i have moved the relay related to the injector ignition you can hear it clicking and making contact. engine will turn over. it is itermitent on my vehicle.
since you mention fuel pump , I know you do have a good cranking of the engine.. Fuel pressures must be measured with a guage as mentioned by MT 2500...this is the other possibility , of why the engine won't start and no codes. "WITH" dtc codes the MAF and crank/cam sensors as well as other componets can cause this.. |
I have a 04 suburban 8.1 liter.
Mine did similar, they have a bulletin to replace certain fuel pumps, they said that certain altitudes affected the fuel pump so they replaced mine with the new version. I dont live in Mt Everest, just Denver. |
