Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-01-2010, 09:53 AM
redturbo66 redturbo66 is offline
Electrical issues on 99 GST Spyder
Here it is: I got no power windows, no stereo, convertible top won't go up or down, and the door locks don't work. My battery loses voltage overnight without car running. I tried changing out the window switch relay.....nogo. Any help would be appreciated.
Old 11-01-2010, 10:34 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Electrical issues on 99 GST Spyder
So the battery is dying nightly? If so, there is a drain somewhere or its an old battery. Get it charged and hook up a voltmeter up to it. Then start pulling fuses and watch the amps. When you pull a fuse and it the drain drops, then you have something running on that circuit. Then just try to figure out what's pulling on that circuit.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-03-2010, 08:50 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
It must be a big drain to kill a battery each day. Do like dave said get a multimeter and switch it to amps, remove the neg terminal and put the meter between the ground and the battery. It will probably be pulling some current. Anything over .2amps is draining the battery. Some current will be pulled by the radio, clock, etc small things that continue to run but will not drain the battery. Be careful to not overstep the rating on the multimeter some cheaper ones are only rated at .5A of so and will blow a fuse if you put more of that through them.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 11-03-2010, 09:06 PM
ned032002's Avatar
ned032002 ned032002 is offline
When I had this same issue, I pulled the negative terminal off the battery and put a test light in between the post on the battery and the ground wire. The light will most likely light up (if it doesn't light up, then you either hooked it up wrong or there is no draw). Then just start pulling fuses until the light goes out or goes very dim. My draw was involving the dome fuse, and this technique worked awesome. Just so happen to be the last fuse I pulled and the light went right out.
99 Sebring Conv. electrical issues Foxypsycho Sebring | Sebring Coupe | Convertible 0 05-13-2010 06:54 PM
New electrical issue Malacite69 Cavalier Problem Diagnosis 0 03-09-2010 03:33 PM
2001 ZR2 electrical issue airboss20 Problem Diagnosis 4 12-26-2009 08:59 PM
1998 Passat Electrical Issues mns247365 '97+ 2 05-22-2009 01:36 PM
2001 cav electrical issues Raeven Cavalier Problem Diagnosis 0 04-29-2009 10:23 AM
