Go Back   Automotive Forums Car Chat > Honda > HRV
Old 10-28-2010, 03:53 AM
piyush1 piyush1 is offline
Banned
Honda HR-V 1999 1,6 - problem with CVT automatic gearbox?
Object: Honda HR-V 3D 1999 1,6 CVT 185.000 km
I suspect the CVT gearbox is faulty, it generates a severe vibration /
noise when I pull off from a standstill. This vibration does not exist
if I pull off very gently or if the car is already moving with a low
speed. Vibration / noise lasts for a one – two seconds while the car is
accelerating and disappears (it appears just at the moment while the
wheels start rotating). It is much worse if I pull off uphill.
Any advise?
Thanks a lot in advance.....
Old 11-27-2011, 06:37 PM
jwvandegronden jwvandegronden is offline
Re: Honda HR-V 1999 1,6 - problem with CVT automatic gearbox?
just for the record (I assume your issue has been dealt with)
I have been looking extensively for a HR-V CVT, and had my old garage check an available car on quality and maintenance. During the test drive I experienced similar issues, driving away from a standstill gave a shutter, which indicates an issue with a neglected recall for these series. At least the CVT should be rinsed, and oil replaced according to manual. From factory they had used wrong oil, and therefore recall was issued. And they extended the warrenty up to 10 years.
So please check if recall has been performed on your car!
Other than that, maybe regular wear and tear? 185000 is quite a mileage but shouldn't be an issue.
Good luck!
Old 01-01-2013, 09:14 PM
sonda sonda is offline
Any advise?
U need to use the Honda genuine CVT oil. if u haven't use it before.. use it immediate.
if the problem still there, then u need to clean the valve body in the transmission.
Old 10-31-2014, 01:09 AM
bwalyakandani bwalyakandani is offline
Hi everybody, thanks for the birthday wishes.
I also have a CVT issue with my 2002 HR-V. It constantly changes revs up and down as I try to accelarate. The problem is more when engine is cold.
Any help please
Old 11-02-2014, 08:39 PM
Smile Re: Honda HR-V 1999 1,6 - problem with CVT automatic gearbox?
Hi mate,
it seems to me like you having a issue with your IAC ( Idle Air Control ) valve. take it out from the throttle body & clean it with TB cleaner & place it back carefully. erase the memory by pulling the memory backup fuse or disconnect the battery.. now you are good to go!
Problems with my 1999 Mazda Millenia V6 2.5L IcyBob Millenia/Xedos 9 0 01-04-2010 06:04 PM
Differences between '05 and '06 1.6 Engines? edr_bug Aveo 0 08-06-2009 11:51 PM
1999 Chevy Blazer problems with Brakes mcelroy420 Problem Diagnosis 12 01-15-2007 03:14 PM
1999 Grand Cherokee problems with passenger side power windows, locks, mirror mklein Grand Cherokee | Grand Cherokee SRT8 9 07-03-2004 06:10 PM
problem with my automatic transmission sebaxx Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 01-21-2003 12:06 PM
