Old 10-27-2010, 09:10 AM
wish4you wish4you is offline
Unhappy 03 Ford Windstar SE frozen compressor...Is there an easy fix?
I have a 2003 Ford Windstar SE
I need help with figuring out how to fix it.
The Problems:
  • The van starts without the serpentine belt but it wont start with it on.
  • There's no radiator fluid
  • The battery is perfect
  • The ac compressor is frozen and wont move and so my serpentine belt now won't turn.
So my question is can I bypass the compressor for my serpentine or is there anyway that I can rig my car so that it runs?....I don't care if there's air conditioning.
P.s.
Please help this car is just costing me so much money and time.
Old 10-27-2010, 12:35 PM
tomj76 tomj76 is offline
Re: 03 Ford Windstar SE frozen compressor...Is there an easy fix?
You may be able to use a shorter belt, skipping the A/C compressor. However, the path must be clear and have some spare clearance.
Old 10-28-2010, 01:06 AM
mark_gober mark_gober is offline
The Problems:
P.s.
Wish,
On not 100% sure on this particular vehicle, but I know for a fact that on the Ford Taurus with the 3.0 l engine that there is an a/c compressor bypass pulley for this exact purpose. Without buying one, I can assure you that you can just a shorter belt and make it work. The difficulty will be in figuring out just how short of a belt you need. It'll probably not be located in any manuals.
Good luck,
Mark
Old 10-28-2010, 08:55 AM
12Ounce 12Ounce is offline
[b]......[*] There's no radiator fluid.......
Are you saying there is no coolant? If so, this must be attended to before any thing else. Do not run the engine without coolant.
2000 Ford Windstar, Not a whole lot of knowledge cshawn Windstar 8 08-14-2010 06:40 PM
I love the Ford Windstar 1999 serge_saati Cars in General 0 05-09-2009 03:51 PM
Frozen gas lines?! What is there to do? dudealex1 LeSabre 30 01-13-2009 10:55 PM
Is there an easy way to fix? Teddey Impreza/9-2x/Outback Sport 3 12-16-2006 11:16 PM
[1997] Loose seat belt spring tension - is there an easy way to fixing it? 1997Camry Camry/Camry Hybrid/Vista 2 06-01-2004 10:05 AM
