Old 10-26-2010, 08:52 PM
GregGP GregGP is offline
Extended Life Motor Oil
It's about time for an oil change on my grand prix, and I was curious to see if anyone has used that extended life oil.. Mobil 1 claims that the 'extended performance' oil of theirs is good for 15,000 miles. Is there any truth to this??
Old 10-26-2010, 10:32 PM
danielsatur danielsatur is offline
Re: Extended Live Motor Oil
Anytime you use extended life oil, make sure you check your oil weekly!
Old 10-27-2010, 02:04 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
And use a decent filter. WIX, Mobil1,.....
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-27-2010, 01:03 PM
So you guys think the oil would actually be good enough to leave in there that long? And how do you think the 'oil life computer' would be affected?
Old 10-27-2010, 06:24 PM
You probably could get away with just changing the oil filter every 5k miles.
If you want to run your car Greener for more than 7years/100K Miles, see
http://www.ideabuyer.com/ipavail/acme-emissions-filter
Old 10-27-2010, 06:38 PM
3100 3100 is offline
Banned
Oil life is determined based on many parameters, but the most importan ones are: engine rpm, engine starting and shutting off temperatures. However, I don't think that there is sensor that will measure the actual quality of used engine oil, so maybe somewhere between 4000-6000 your engine oil life will show 0% depending where and how you drive.
Old 10-27-2010, 07:24 PM
That's what I was thinking 3100.. And as far as being 'green' goes, I'm not concerned about it. I was just curious if anyone had used that kind of oil before. I'll leave being green to the prius drivers!
Old 10-28-2010, 06:09 PM
tblake's Avatar
In God We Trust
I didn't say that per say...
I said that if you do decide to not change your oil for an extended period of time, to make sure to use a good filter.
The decision to run longer than 3-4k off an oil change is up to you. I know for sure that I wont. Its a cheap way to keep your motor in good shape and stay awar of internal engine issues like coolant contamination.
Old 10-28-2010, 06:34 PM
GTP Dad GTP Dad is offline
Pontiac Guy
I don't want to get into a pi--ing match here concerning extended oil drain intervals. However, with new metalergy and better quality oils, especially synthetic, I see nothing wrong with extended life oil. I have used Mobil 1 and run it for 10K miles without changing it and had no ill effects on the engine. I also have used Amsoil (which I prefer) for one year intervals and I have gotten excellent results.
As tblake says you must use a good quality filter. The filter is probably more important than the oil itself. Wix makes an excellent filter. I don't recommend the orange can of death (Fram) or other cheap filters especially if you intend to wait 10-15K miles before changing.
Old 10-28-2010, 06:36 PM
Thanks again Tblake.. I wasn't really planning on it either (at least not in my car) I was just curious. I wouldn't be able to trust it anymore after about 4K.
Old 10-28-2010, 06:39 PM
A YEAR?? Wow, that's pretty impressive! I don't think I could do it though.. Out of idle curiousity though, where do you buy Amsoil? I have heard lots about it, but I have never seen it..
Old 10-28-2010, 07:49 PM
tblake's Avatar
In God We Trust
Yeah, my g/f just signed the truck and her car up on the valvoline 250k engine life guarentee. I just missed the 125k mile interval with my car. The stipulations include that you have to use valvoline from the point of signing up and continuously throughout the life of your car. And you have to save all the valvoline receipts for proof. Another stipulation is that you have to change your oil between 3000-4000 mile intervals, no exceptions and you have to go online and update when you change. If you go past 4000 miles, I think it voids the warrenty. It stated that the 3000-4000 k change interval as stated in the owners manaul is only for driving in extreme conditions. Which the valvoline website says is what the majority of drivers fall into. Obviously they are in it to sell oil and make money, but I've maybe went past 4k miles once on a change of oil, and even at or a little before 3k miles, my oil comes out black and used up. So I change regularily.
Old 10-28-2010, 09:52 PM
doctorhrdware doctorhrdware is offline
Amsoil is usually sold at independent auto parts stores. At least in my area around me.
Old 10-28-2010, 09:57 PM
How much does it cost for 5 quarts of Amsoil?
Old 10-29-2010, 06:39 AM
BNaylor's Avatar
BNaylor BNaylor is offline
How many miles do you have on your Grand Prix GregGP?
I would exercise caution switching to synthetic from dino oil with a high mileage engine or using extended performance synthetic. Many reports from SII 3800 owners about higher oil consumption and screwed up valve stem seals as a result and various seals or gaskets leaking due to old age, etc.
For a daily driver I'd stay with good quality dino oil. Most are good up to at least 5K miles now. Thats all I use in my non-modded Grand Prixs and other GM cars. I use regular Mobil 1 synthetic in my GTP.
Timeslip 08/12/06
AF Community Guidelines
intermittent/no heat problem fix(Dex-Cool Extended Life Engine Coolant) kbrdg M Bodies 2 05-27-2005 01:59 AM
Press Release On Extended Life Oil rudyhiebert Automotive News Desk 0 04-22-2005 12:52 PM
extended-life antifreeze rogersunspirit Accent | Verna 0 08-31-2004 06:15 AM
Tags
oil
