Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 10-26-2010, 10:34 AM
Shawley3's Avatar
Shawley3 Shawley3 is offline
96 neon engine swap to srt-4
Just wanting to get some insite from experienced people. I was looking to do an engine swap on my 96 dodge neon. I want to put a bigger engine in (prefferably an srt-4 engine with a stock turbo already in it. Just want to know of any problems and extra parts I may need to include. I had planned on going to the junkyard to pull a motor and throw it in. Any advice is much appreciated.
Old 10-26-2010, 12:55 PM
Oldsmobile Doctor Oldsmobile Doctor is offline
Re: 96 neon engine swap to srt-4
Wiring harness and ecm for sure. You Will have to wait on someone who has done it about fitting it in as the 2 gen (2000 and up) has more room between the engine and fire wall. Plus the 2.4 is taller and the 2.0 twin cam has a bump in the hood to fit the 1st gen (1995 to 1999)
Old 10-27-2010, 08:39 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
You wouldn't be able to use a used PCM from the SRT-4 as it has seen sentry. You would need a new PCM that hasn't seen sentry yet. The swap has been done and done successfully multiple times by different people. It's a lot of rewiring and electrical work. Not an easy swap, but very very doable.
The link below is a great how-to...
http://dodgeforum.com/forum/1st-gen-...e-nv-t350.html
2003 Dodge SRT-4
Engine Swap rbneville Skylark 1 07-13-2010 03:06 PM
swapping 91 wrangler 4.0 for 97 cherokee 4.0 - fuel lines mismatch rykowalspt Wrangler 1 03-26-2009 06:07 PM
Nissan Quest V6 to 2.4 ltr 4 cylinder swap Scraped Knuckles Quest | Presage | Serena 4 02-20-2009 09:59 AM
2001 neon r/t / srt-4 Frankie Newport SRT4 4 04-06-2005 02:24 PM
Motor Swap Srt 4 motor in a plymouth breeze Breezin Breeze 1 03-22-2005 09:56 PM
