I had the misfortune of having both lenses on my 98 GP fall off and I replaced one about three years ago and the other this past summer. I happened to park in the driveway with the garage door closed and noticed that the right lamp is way higher than the left one. Since both were replaced with used ones from the wrecker, I don't know which one, if either, is accurate. Can anyone tell me what the correct height should be and which screw is used to make the adjustment?
Re: Headlamp Aiming
I guess there were no takers on this one. Are you referring to the physical mounting of the headlamps on the header panel/front frame or adjustment of the beams?
Re: Headlamp Aiming
I am referring to adjusting the beams.
Re: Headlamp Aiming
See the old thread (posts 3 and 4) below which should help. Aiming procedure and covers the star adjusters on the headlamp assemblies.
Click here
Re: Headlamp Aiming
Once again you have come to my rescue! I had to go to an industrial area to get the space (25') and a relatively flat surface but I think it worked. They look the same to me now. Thanks again Bob.
