Old 10-25-2010, 01:52 PM
JohnnyWadd JohnnyWadd is offline
How Hard Is It To Change The Heater Core On A 1999 Cavalier?!
So, my girl drives a 99 Cavalier and the heater core just went out. I fancy myself to be a bit of a mechanic, so I'm wanting to fix it myself. Problem is, I know that sometimes these heater cores can be a bitch to change. Anybody got any helpful advice here?
I went out my buddy's shop and looked it up on All Data... it calls for 6.5 labor hours. Should I expect it to take every bit of that, or can I assume that I'll get her done a bit faster? I don't wanna spend a whole day on this if I don't have to.
I know the console's gotta come out. I don't have to take out the radio and heater control assembly, do I? I'm just hopin' that I can leave all of that stuff in place... wondering if anyone can confirm or disconfirm this for me. The less I have to take apart, the better!!
Any help you can give would be greatly appreciated...
1991 Talon TSi FWD 2.0L Turbo
Old 10-29-2010, 06:42 PM
Re: How Hard Is It To Change The Heater Core On A 1999 Cavalier?!
Hello?!!!
Is there anybody out there?!
Old 10-29-2010, 08:32 PM
inafogg inafogg is offline
never did a cavalier but would'nt think the g/am is too differant
console,shifter.lower dash(under a/c controls)alot/most of dash trim
it was'nt fun and 6-7 hrs sounds right.(if the cars are simular) 98 G/AM
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-07-2010, 10:02 AM
Well, piss on it... I'm about to jump in head first. I'll let you know how it goes...
Old 11-13-2010, 08:34 PM
Helmuth48's Avatar
Helmuth48 Helmuth48 is offline
Never did a Cavalier...but I did a 95 Firebird....it was a real pain and took me two days and a case of beer.... Cheer Mate.. good luck...
Old 11-20-2010, 03:19 PM
That friggin' SUCKED!!!
I ended up disassembling some stuff that I didn't need to, but in the long run, it helped me. Broke a few things, too... the plastic gets brittle over time and if you've missed a bolt or screw, it's easy to break the plastic when you tug on it.
The big thing is that I couldn't get the cover off of the heater core. I thought I'd removed all the bolts... turns out I hadn't. There's one tricky little bugger toward the right front of the cover that's really hard to get at. Once it's out, though, the job's a breeze.
Reassembly goes a lot easier. All-in-all, it was time consuming, but not overly difficult. Just make sure you get that bolt that I was talking about... that little guy added probably an hour to the job for me. I couldn't figure out why I couldn't get the cover off.
But, it's over now... no more leaks. If you know something about cars, you should be able to handle it. Just be patient and don't get mad like I did.
Good luck.
Old 11-20-2010, 06:19 PM
glad to see you got through it.yea plastic is a bitch & then rattles if not secured
after you calm down(few beers)its all worth it,& you saved alot of $$$$!!!
make sure you bleed cooling system(if needed)
Live For Today
Yesterday is gone,
Old 01-01-2011, 04:50 PM
Modeeb Modeeb is offline
JohnnyWadd, I'm doing the heater core on a 2001 Cavalier but can't get the cover off. I removed that rear screw at the very back and all others. The cover seems "loose" yet is still seems to be getting hung up on something. Drain hose maybe?
Did you pull straight down or pull the cover backwards? Can't get the cover out for the life of me.
Any help appreciated.
how to change a heater core in ford 1999 Taurus sallygq Taurus | Taurus Wagon 3 11-25-2008 01:33 PM
How do you replace the heater core in a 1994 GMC Jimmy? RusyJimmy Problem Diagnosis 1 10-28-2006 12:36 PM
Changing the Heater Core, Help.. mercedes420 Camaro Discussions 1 02-23-2006 05:05 PM
how to remove the heater core? ford460bigblock Non-Performance 0 11-10-2005 06:25 PM
