Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 10-25-2010, 09:29 AM
goadster4 goadster4 is offline
Clanging sound from Belt area???
I have a 2000 Montana with 143,000 miles on it. For about the past 3 months it has had an intermittent metal clanging sound coming from the engine. It sounds a lot like a someone tapping on a pulley, but before I pull things apart i want to see if someone might know which one is suspect or if it might be something like the timing chain. One other thing that I've noticed is when I turn the AC on the noise goes away. When I turn the AC off, it comes back. any advice is appreciated.
Old 10-25-2010, 12:34 PM
rkvons's Avatar
rkvons rkvons is offline
Re: Clanging sound from Belt area???
I don't think your engine has a timing chain. You can take the serpentine belt off and see if any pulleys are loose. Also see if your idler itself is loose.
Old 10-25-2010, 01:21 PM
3100 3100 is offline
Banned
AC compressor air gap is too close, you have to use special tool for V5 compressor to adjust the gap.
this is your problem 100% I am GM master tech 14 years, and disregard this negative reputation, one of the moderators did not like my suggestion and gave me one negative point. Please give me thumbs up to fix this. Thank you 3100
this is the tool that you need: http://www.sjdiscounttools.com/kdt3340.html
it is also easy to do it you don't have to disconnect ac compressor lines, you have to remove two bolts on top and one on the bottom so that ac drops down this way you will have space to use this tool.
Old 10-25-2010, 06:21 PM
I will give it a try. is there a step by step guide that shows the work on the internet? I have never had an issue with it before, but I did add freon to the vehicle this summer. Could this be something that messed it up? I don't have a lot of experience with ac units on vehicles.
03 oddyssey crackling sound from dash area AngelDust72 Odyssey 0 03-24-2008 01:24 AM
96 aurora ssqueeking sound from trans area bengal3 Aurora 0 06-19-2007 08:14 AM
Clicking sounds from Passenger Area Anthonie TrailBlazer | Trailblazer EXT 2 03-23-2006 01:07 PM
Clunking sound from wheel area (rear passenger side) at low speeds, bumps DocShock Cavalier 1 09-14-2005 03:30 PM
Moaning sound from windshield area ace395a Montana/Montana SV6 0 02-24-2005 08:05 AM
