Go Back   Automotive Forums Car Chat > Saturn > Ion
Old 10-24-2010, 06:28 PM
autotech.kb autotech.kb is offline
04 ion wont start
I have an 04 Ion and it is not starting. I think I located the problem. The "ECM Cont." relay number 31 under the hood at the eps is not working. I changed it with no luck. I checked a number of things including every fuse by a dmm continuity test and pulled them all out and visually verified. all test fine. the issue i think is the ecm cont relay does not trigger, if i jump pins 87 and 30 with the key in the ignition in the on position it starts and runs fine. so i checked and found the triggers come from the clutch in the car which appears to send +12v to trigger the relay. that seems fine. the other trigger appears to come from the starter coil relay and is yellow coming from the ecm pin 66 i think. how can i fix this ecm wire issue?????????
I attached the circuit diagram ive been using to try and track down the problem
please help!!!!!! thanks so much guys
Old 12-11-2010, 04:56 PM
denyp denyp is offline
Re: 04 ion wont start
Does this happen all the time or just since it got below 20 deg. outside?
Deny
Car wont start or dies/Code reader error/Bad ground? jzbeaver Windstar 1 11-08-2010 02:12 PM
98 Grand Prix Wont Start, need help ASAP! atdudonis Grand Prix 3 06-17-2010 08:57 AM
97 Yukon wont start, but after turning key over&over it starts up. zerolimitsGT Yukon 2 06-12-2010 06:00 PM
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
