Old 10-24-2010, 09:24 AM
boatbuster boatbuster is offline
02 Astro AWD Ball Joints Help???
I am attempting to replace the lower ball joint on the passenger side. After hours of cutting and hitting and such, I was able to remove the bolts that are holding the ball joint in place - obviously someone had replaced it before since there were no rivets. Now I am trying to figure out if I have to remove the axle to have enough clearance to pull out the ball joint or is there a way of doing it without removing the axle.
My top ball joint is riveted so I don't think the top one needs to be removed to remove the bottom.
Any help would be greatly appreciated!!!
Old 11-19-2010, 01:13 PM
RolandMD RolandMD is offline
Banned
Re: 02 Astro AWD Ball Joints Help???
I have a 97 AWD, and as far as I know the lower ball joints are a press fit (not the uppers). Please check, but unless you have a press, you might not be able to seat the lower ball joints properly. Remember, the front ends of these vans are heavy, so this type of wear is common.
94 Astro AWD - front brakes? stan_5150 M Bodies 2 04-06-2010 07:47 PM
ball joint? tie rod? HELP! cjedstrom Cougar 2 11-26-2009 05:53 PM
lower ball joint help 1PhatCX '88 - '91 Civic | CRX | Wagon | Shuttlee 13 10-18-2004 12:02 AM
1992 f-150 super cab Ball Joints HELP!!!!! 94gpse F Series 1 04-20-2004 08:47 PM
Ball Joint help Sally2Trees Crown Victoria 2 02-20-2004 04:45 PM
