Old 10-23-2010, 12:39 PM
hayesbcajh hayesbcajh is offline
Rear brake line
I'm working on a 2002 Voyager 2.4l with rear drums. I'm doing a complete brake job. When removing the brake line from the passenger side wheel cylinder, the hose must have been terribly corroded so as I turned the nut, the metal hose tore away. So now I need to replace this hose. The metal portion connects to a rubber portion. It looks like it is all 1 piece until a connection where it goes thru the frame after that. Two questions:
1. Is it correct that I need to replace the metal and rubber hose as one unit?
2. There are 2 clips that hold the hose in place. One is easily removed. The other looks like it's part of the axle plate that holds the leaf spring. Must I remove the axle plate to get the hose off? I have the car supported by jack stands on the rear axle so there is pressure on the springs, I think.
Please help.
Old 10-25-2010, 07:11 AM
Re: Rear brake line
I got some help from someone with more experience and got the job done. The hose is one unit, metal to rubber. And I was were able to leave the car jacked up by the exle and remove the 2 bolts holding the brake line bracket down.
rear brake line routing on 85 corolla fx? mike5721947 Corolla/Matrix/Voltz 2 12-15-2005 01:16 AM
Rear Brake Line Replacment redheadedone4ever Roadmaster 1 03-11-2005 06:28 AM
Rear Brake Lines... cujotom Cavalier 3 02-28-2005 08:59 PM
93 F150 rear brake lines SUMOBOY F Series 0 08-20-2004 07:16 AM
