Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 10-22-2010, 04:47 PM
cjstew4 cjstew4 is offline
94 camry 239k miles no stop,tail, backup lights
Replaced the broken harness that houses the tail/brake and backup lights since I was using it instead of the surrounding metal to bungey the trunk lid down. Still no brake or tail lights working on the trunk or body as well as no back up lights. Fuses all test good. Should I start tracing the wire harness inside the trunk lid back from the known good harness to find the problem, or can anyone give me another possibility since I only have the 3rd brake light working. Turn signals and license plate lights work fine. thanks.
Old 10-24-2010, 10:26 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 94 camry 239k miles no stop,tail, backup lights
Did you replace the part of the harness that runs by the trunk lid hinges? If not, that is a common place for damage to occur to the harness.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-24-2010, 10:29 AM
I did not replace this, but will check it out since I know that flexes plenty and probably is contributing. Thanks.
Old 10-24-2010, 10:47 AM
Scrapper Scrapper is offline
AF Premium User
i just went threw this on my niece's car had no lites at all front and rear and there was a broken wire on her turn sigal switch so you may want to change it if other things there telling don't work?
Old 10-24-2010, 11:24 AM
Thanks, will check that out as well.
Old 10-27-2010, 12:43 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If the harness is good then check the taillight bulb failure sensor module located on the driver's side near the wheelwell. These have been faulty as well.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 11-05-2010, 05:13 PM
The harness where the trunk hinge is appears good, no stresses, but not electrically tested. Did remove the yellow taillight sensor module at the driver's side trunk wheel well behind the protective liner. It appears ok, but did not test it. Dealer wants $303 w/tax for it. As my third brake light only works, when I took out this yellow module, the 3rd brake light did not work, and worked when I plugged the module back in. Does that mean the module it fully OK?? I am trying to get it to an electrical shop, but they all want $84/hr. Any other suggestions on this to check before I drink their $84 free cup of coffee and await some quick solution that they will of course find making me appear very dumb?
Old 11-05-2010, 05:29 PM
inafogg inafogg is offline
yea $84 i'd invest in a wiring diagram
good luck
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 11-06-2010, 12:44 PM
Mike Gerber Mike Gerber is offline
AF -Advisor
"The harness where the trunk hinge is appears good, no stresses, but not electrically tested."
Open up that loom and visually look at the wires inside that harness. Look for frayed or broken wires. If you don't see anything obvious, I would test those wires myself.
Mike
Old 12-29-2010, 02:47 PM
Turns out it was the taillight bulb failure sensor module which I got for $30 used at a salvage yard. All the rear lights work now. Thanks for everyone's input.
No Tail light or Dash Lights THernandez SC/SL/SW 2 04-04-2009 06:16 PM
1993 Toyota Camry Trunk Mounted Running & Backup Lights mpetner Camry/Camry Hybrid/Vista 2 01-03-2008 03:03 PM
87 Mustang GT Tail-Lights to Lx Tail-lights emokid15 Mustang Talk 3 01-26-2005 10:05 AM
