Old 10-22-2010, 10:55 AM
Spanish Bull Spanish Bull is offline
F-350 - Syntheitic or regular oil?
Just wondering what you fellow F-350 owners use for engine oil. I plan to stick to the mainetenance schedule (every 6 months).
Old 10-22-2010, 01:05 PM
jyount jyount is offline
Re: F-350 - Syntheitic or regular oil?
What year, what engine? Synthetic has its place, but it is costly, and I don't care what oil scans say and all that bull you cannot tell me that 30000 mile oil changes are safe for anything.....
I know you said you will stick to the schedule, but alot of people don't.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 10-22-2010, 04:14 PM
The truck is a 2010 turbo diesel 6.0 litre.
Old 10-22-2010, 06:02 PM
A High quality dino would be fine. Do not skimp and get cheap oil. The epa has got the diesels running so hot in areas the oil goes now that cheap oil will coke.
Synthetic is good but it is very high. I'm talking 125 dollar oil changes.....
Current job: RN
Wife's
Old 10-26-2010, 08:39 PM
big white bufflo big white bufflo is offline
my take on synthetic i have a 97 7.3 145000 i went syn oil but switch back if you look around hi mile moters are prone to leak after the swich is what mine did so i switch back and the leaks stopped but in alot of cases if you switch change it every other oil change about 10000 mile just change the filter every 5000 and your looking at 150 + $ to switch
Old 10-27-2010, 12:08 AM
I miss mine ALOT. I had a 97 too, best truck I had up until it and best I've had yet..
I also ran synthetic for about 20k before I sold it. I had mine from 65k miles, drove it everyday and changed the oil like you should. As long as it doesn't sit so that seals harden up, and it is maintained like it should be, it shouldn't leak. Like he said though, if gonna do it, it is better to start early, not high mileage. The absolute best side note of the synthetics is they are generally more stable at given temperatures and they can cover a wide range of viscosities. I ran 5w-40 and the winter starting with 5w is amazing. The starter has very little load even at icy cold temperatures at that low of a viscosity.
Albeit a smaller concern with your truck, as the old body style 7.3 had OEM starters that left a ton to be desired, the injectors were also fired with oil pressure where yours is not, so the older trucks had exxagerated effects that made the switch worth it, not sure yours would be...
Current job: RN
Wife's
Rocket 350 vs. regular 350 - Whats the difference? brutus90 Engineering/ Technical 21 05-20-2008 07:43 PM
synthetic blend VS. good quality regular oil? BlazinUP S-10 51 12-22-2004 02:06 PM
Syntec Oil vs Regular Oil Bxcivic2000 Let's get Technical! 17 06-08-2004 12:27 PM
Running Synthetic after running regular oil DJ JEFF C/K 5 02-16-2004 06:40 PM
synthetic or regular oil? greekman Maintenance 1 08-10-2001 10:07 PM
